Solis Inverter S5-GR1P6K ....
following on from my other post, i have seen the above inverter and have been told it will be able to provide 6kw per hour from the grid to charge a large bank off the grid during the winter using off peak electricity.
i checked the information and it shows this
bt i am confused about what that means is it saying that 12.5A + 12.5A, it would charge at (2 x 12.5A x 240v) 6kw per hour from the grid or does that mean 3kw from the grid and 3kw from PV ?
Posted by: @misterb12.5A + 12.5A
That is the input current from the PV (I.e. per MPPT current limits).
- 2,775 Topics
- 65.4 K Posts
- 3,775 Online
- 7,180 Members
Playing some what-if games with the numbers. If the Gov...
By Rob of York , 8 minutes ago
@jamespa You can find £80/kWh home batteries now on ...
By Papahuhu , 48 minutes ago
By Batpred , 20 hours ago
By Toodles , 1 day ago
By tomasmcguinness , 1 day ago
@mrkfm, I'd also suggest that whenever you're ready, st...
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 2 days ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 2 days ago
@downfield I just checked this morning and OE just r...
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 3 days ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 3 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 5 days ago
