Open Energy Monitor
@editor The EmonPi unit is plugged into the mains and the other items are plugged in to the EmonPi.
Ive attached an image of my heatmeter, the grey wire coming up is connected to a USB to modbus adapter like this DSD TECH SH-U10 USB to RS485 Converter for Modbus: Amazon.co.uk: Computers & Accessories and then into my EmonPi. It was a bit fiddle to get the data from the heatmeter, but thats because I was bolting it onto a previously bought emonPi rather than buying the heat pump monitoring kit
- 2,102 Topics
- 46.2 K Posts
- 118 Online
- 3,388 Members
And we have it: DESNZ are now investigating the feasi...
By Lucia , 1 hour ago
@skyefarmer great you located the source of the issue a...
By Mars , 5 hours ago
By ASHP-BOBBA , 14 hours ago
From what you say about the radiators upstairs it does ...
By JamesPa , 20 hours ago
By Mars , 23 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
