Open Energy Monitor
@editor The EmonPi unit is plugged into the mains and the other items are plugged in to the EmonPi.
Ive attached an image of my heatmeter, the grey wire coming up is connected to a USB to modbus adapter like this DSD TECH SH-U10 USB to RS485 Converter for Modbus: Amazon.co.uk: Computers & Accessories and then into my EmonPi. It was a bit fiddle to get the data from the heatmeter, but thats because I was bolting it onto a previously bought emonPi rather than buying the heat pump monitoring kit
10kWh DC coupled battery
- 2,766 Topics
- 65.1 K Posts
- 2,546 Online
- 7,169 Members
The answer is going to depend on what characteristic of...
By Transparent , 11 minutes ago
You should (amost) always reject having a buffer, by wh...
By JamesPa , 32 minutes ago
By Toodles , 4 hours ago
@majordennisbloodnok I do sympathise. On the original...
By springswood , 6 hours ago
No, but the heat pump must be capable of delivering a S...
By JamesPa , 10 hours ago
Sorry to hear about the problems, its going to be somet...
By JamesPa , 11 hours ago
By bobflux , 24 hours ago
By cathodeRay , 1 day ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 1 day ago
I have seen it stated that the declared calorific value...
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 2 days ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
@batpred thanks for getting a copy. Appreciate the supp...
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 3 days ago
