Octopus Energy new Cosy tariff.
I found a short paragraph somewhere where mention was made of OE offering Texans an intelligent tariff to use if they have a Tesla Powerwall. I could not determine whether this sort of tariff is or will be offered in the UK so have written to OE for further enlightenment.
Without an EV, I am unable to go for the Intelligent Octopus Go so will be interested to see if this is a new way into such tariffs with very low cost overnight rates. (Meanwhile, Octopus Cosy still seems to be cheaper than Agile has been of late.😊) Regards, Toodles.
- 2,118 Topics
- 46.5 K Posts
- 21 Online
- 4,522 Members
By Mars , 9 hours ago
@adamk what a shambles. Can you share some pics of the ...
By JamesPa , 13 hours ago
So the manual is correct and looks fine to me, to abbre...
By ASHP-BOBBA , 19 hours ago
By Transparent , 20 hours ago
By normpang , 21 hours ago
By ASHP-BOBBA , 2 days ago
By Burtis , 5 days ago
By JamesPa , 5 days ago
By Old_Scientist , 6 days ago
By Lucia , 7 days ago
By Ashfp , 7 days ago
By Mars , 1 week ago
