E.ON Portal sign-in
- 2,367 Topics
- 53.7 K Posts
- 105 Online
- 6,042 Members
@z8lccda, you’ve just described my setup - Growatt SPH5...
By Majordennisbloodnok , 6 hours ago
Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
Good Evening. Has anyone found the following when usi...
By Nursethescreens , 8 hours ago
RE: Help needed with Grant Aerona 3 issues
First time posting so bear with me. Some bits that have...
By Adamp , 11 hours ago
RE: Mitsu PUHZ-SW120YHA + EHSC-VM20Uk - Performance
All understood. Obviously its a bit house de...
By JamesPa , 12 hours ago
RE: Water Hammer After Heat Pump Install
From OPs description I had the impression (quite possib...
By JamesPa , 14 hours ago
@majordennisbloodnok This may be a better thread to ...
RE: Best Heat Pump Brand in the UK
Last Call to Vote & Win! Haven't voted for your Hea...
Interesting question. To be frank, since I have no inte...
RE: Changing from 4-port buffer to volumizer
@andy1618 see the very sage advice from @editor above. ...
The video shows the JK balancer, but the connection of ...
RE: Ecodan unable to hit legionella target temp - what's the consensus?
@9jwr9 Hi, yes this is the issue with every (stand alon...
By ASHP-BOBBA , 2 days ago
@adamk FWIW I managed unintentionally to 'coax' mine in...
You are in essence right. Adia only works with selecte...
No, you haven’t missed out, @batpred. This thread’ll st...
Also, though they weren’t prepared to match the price t...
RE: How long will your energy contract last?
My INTELLI-FIX-12M-25-08-29 has less than 12 months to ...
By Batpred , 3 days ago
RE: GivEnergy 2025 forthcoming batteries and inverters
Then, perhaps @toodles , you should've made a submissio...
I am wondering if anyone with an EV could find the 7p/k...
Possibly, but it would also reduce DeltaT across the em...
