New hot water cylinder future proofed for heat pump?
Hi Forums
I plan to change an old hotwater cylinder now, for a modern un-vented one, with immersion heater I can use with an Eddie and my PV system.
I currently have a reasonably new mains gas system boiler for heating and hotwater.
I plan in next few years to extend and insulate house and hope to fit ASHP at that time when property requirements are known.
Will a cylinder advertised as made to work with ASHP, work with current gas boiler? I assume it will make no difference to cylinder operation if boiler flow temp is set lower, but a plumber I talked to said they where all incompatible...
Help much appreciated
Hi, @Pen-y-Bryn I had exactly the same situation as you and went for a Mixergy Unvented cylinder. It has a conventional heating coil and immersion heater but also has ports to add a heat exchanger for a future heat pump.
In the end I bit the bullet and took out the gas combi and fitted an ASHP before fitting the cylinder, but my original plan was to do as you are considering. I have plumbed things so I can add the heat exchanger but at present just heat my water via an Eddi. I thought I would monitor things to see if it was worth adding the exchanger.
All th details are in my blog, the address is in my signature.
Sunamp Thermino Heat Battery
4 months ago
Hot water cylinder in unheated space
2 years ago
- 2,356 Topics
- 53.4 K Posts
- 313 Online
- 6,017 Members
RE: External pipework insulation
Oh Dear! that's appalling pipe work, should've been in ...
By dgclimatecontrol , 34 minutes ago
By Morgan , 1 hour ago
RE: Controlling Daikin Altherma via P1P2 and Home Assistant
On the contrary, @toodles, that’s a lot of help. I’d ne...
By Majordennisbloodnok , 3 hours ago
@kevh with the Cosy 6 I know it definitely goes to arou...
By HarrisonC , 15 hours ago
@cathoderay yes I am familiar with SQL. Interesting num...
By RobS , 16 hours ago
Parsnip, Bacon & Coconut Milk Soup
First let me say, I am only a cook because I am human a...
By Toodles , 17 hours ago
Ben Watts posted on LinkedIn that he had updated this w...
By Judith , 22 hours ago
Small update, Emailed and Spoke to Midea UK and they ...
By Burtis , 23 hours ago
@bash Octopus does charge for the admin. The process al...
By Batpred , 23 hours ago
Issues still under investigation by Solis... Fogstar ...
I agree, the consumer is not being properly represented...
RE: Advice on internal circulation pump noise
Thanks @mikefl - I'll maybe have a look at the lock-shi...
By jtg , 2 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@toodles interesting suggestion, thanks. I will try to...
By GrahamF , 2 days ago
RE: Mitsubishi Ecodan Auto Adaption trial to stop cycling.
The interval you talk of, i think, will be 60min for an...
Agree with @majordennisbloodnok on the setbacks. We hav...
By ChandyKris , 3 days ago
RE: Speedcomfort radiator fans
@deltona the way the links were added broke the page. A...
This has been delayed from what I believe to be this ye...
this is why I provided current flow temperatures in the...
By ksim , 3 days ago
