What is the Ideal Heat Pump Temperature for Hot Water?
What Is the Ideal Heat Pump Temperature for Hot Water
We address a common query among homeowners: Can an air source heat pump adequately supply hot water for daily needs? With a focus on optimising operational efficiency, we share our personal experience with setting our heat pump system to maintain water at an ideal temperature of 44°C.
Is Stiebel Eltron the Premium Heat Pump UK Homeowners Have Been Missing?
Can you heat any property with an air source heat pump?
Myths about air source heat pumps
2 Comments
Sapper117
Where and when did this myth start? Bearing in mind the requirement for legionella safety every week it is firstly clear that heat pumps can supply ultra hot water if needed. From there it is simply a matter of dropping temperature and time settings to individual requirements. We find 44-6 perfect and because I have a bath each night I simply leave the hot water heat pump on to top up whenever it needs. We should invest in a gravity feed shower but the en suite was refurbished before the HP and I’m not going to create distruption
I also now tend to fill the kettle with hot 44-5 water as it boiled quicker and should use less power than the hungry kettle
Johnmo
I tried mid 40s only got luke warm showers. Ended up at a 50 degs thermostat setting, plenty of hot water. Zero concern with legionella cylinder usually settles at 51 degs which will kill 90% of legionella in 2 hours. And between 45 and 50 legionella is dormant.
No need to run immersion.
