Ecodan controller.
4 Users
10 Reactions
Morgan
(@morgan)
Topic starter   [#167]
G Morning,
I know Brendon would be able to answer my question but …….
I have an Ecodan ASHP with the FTC in the cupboard with the DHW tank etc.  Alongside that I have this Mitsubishi controller.
6F5F97F4 261F 4E58 876F CB9DC05710A5
This is then controlled via a Heatmiser Neostat v2.  I wish to have this changed to replace the Neostat with the Mitsubishi PAR-WT50R-E remote controller.   https://les.mitsubishielectric.co.uk/products/controls/remote-controllers/par-wt50r-e-remote-controller
I am in possession of the above but need confirmation that I also require the PARWR51R-E in order for this to work?
https://www.swatengineering.co.uk/shop/mitsubishi-electric-remote-controller-par-wr51r-e
The problem is, as Brendon always stated, the neostat is basically an on/off switch thermostat and consequently I will never obtain proper weather compensation. Whereas the Mitsubishi unit is a temperature sensor that ‘talks’ with the ASHP outdoor temperature sensor creating a much more accurate weather compensation curve.
I would be grateful if somebody can confirm my suspicion please.
Morgan.
@morgan, have a look at this; I think you are right.
Morgan
(@morgan)
@kev-m
Thanks Kev.  That’s as I thought.  Need to find somewhere with stock of the wifi receiver and then get the installers back to sort it.
Posted by: @morgan
G Morning,
Morgan.
Hi Morgan,
To answer your questions. Yes, you will also require the receiver unit for the remote controller to be able to communicate with the FTC master controller.
Once weather compensation has been enabled and optimised, and the setting of your thermostat has been increased above the desired temperature, then your system should operate on weather compensation rather than thermostat control.
Once the remote controller has been installed, you will be able to set your system to operate using auto adaptation (Room Temp.) control, which will work along with weather compensation, to control your indoor temperature.
4
Morgan
(@morgan)
This is frustrating.   The best lead time I can get from all the research and enquiries I’ve made is January!  Trying to even get a response is a mission.
@morgan
is that finding stock or getting the supplier back to fit it?
Morgan
(@morgan)
@kev-m
That’s supplying the part.
Jeff
 Jeff
(@jeff)
Posted by: @morgan
In stock in some branches so should be able to get them shipped. Separate links for the transmitter and receiver
https://www.wolseley.co.uk/product/mitsubishi-electric-ecodan-par-wr51r-e-wireless-remote-controller-receiver/
https://www.wolseley.co.uk/product/mitsubishi-electric-ecodan-par-wt50r-e-wireless-remote-controller-transmitter/
Morgan
(@morgan)
@jeff
Cheers Jeff.  I have the transmitter.  It's the receiver I require.  I will have to try again tomorrow as it's available for collection nearby although too late today but appears unavailable for delivery.  Odd.
Jeff
 Jeff
(@jeff)
Posted by: @morgan
@jeff
I think they have a separate warehouse for deliveries that doesn't use the in store stock so that may be the reason.
Worth phoning the store to double check they have one on a shelf. They may also be able to get one transferred from another store if all else fails.
Fingers crossed.
