Solar Panels Installed - hopefully turned on in the next week or so
After a few false starts these and the battery were finally turned on and commissioned yesterday.
Panels performing significantly above expectations. Part sunny part cloudy today and we’ve had results exceeding the rating.
14 panels, 390 watt each should be 5.46KW array but have had as high as 5.88KW production so far.
I believe that the specified output of a solar panel is based upon a standard iradiance of 1000W per square metre. Maximum output can therefore occur during intermittent cloudy days, when the panels are in direct sunlight, but also receiving reflected sunlight from nearby clouds. Unfortunately it is not possible to encourage the clouds to remain in this ideal position throughout the day. 🙄
It started really producing at about 6.30am this morning and so far has produced 35kWh. That has powered the house, charged the battery from 9% to full, put 2.5kWh into the Eddi for the water and exported 4kWh to the grid.
I’m not sure what I was expecting but I’m gobsmacked. It’s been between 12 and 14 degrees and cloudy so not optimal conditions but not bad.
@marvinator80 impressive. We have been toying with the idea of getting similar on our roof.
Still going well. Very cloudy day yesterday so only 15KW. It’s already done 15KW today as the sun is well and truly out so hoping for a record day.
Yesterday my move to Octopus Tracker kicked in so with all these measures combined it’s a total game changer for us in terms of cost.
I’ve signed up as well now to Octopus Outgoing Tariff but it says it will take a few weeks for that to go through. For everything I’m sending to the grid at the moment is that just lost?
I couldn’t se anything up for outgoing until I got my MCS Certificate which was only on Wednesday.
@marvinator80 You say that the temperature was between 12 and 14 degrees; this is very good for panel production; a cool but sunny day may produce more than a warm one might. Panels are ‘speced’ at 25 degrees C and for every degree above that, there will be losses for any given irradiance. I have observed with my Canadian Solar panels (8.1 kWp) that a cool sunny day can be very productive indeed! Regards, Toodles,
@toodles we had that 2 days ago Toodles. About 16 degrees and sunny and we got 35KwH out of it. Yesterday same temperature but very overcast and wet, only 15KwH.
Happy with it and perhaps wishing I had gone bigger. Can add batteries in instalments of 5KW from my current 10 to a max of 20, but the inverter being 5KW I’m not sure it would be worth it.
@marvinator80 I’m afraid my nerdiness requires that one of the first things I look at on my iPhone or iPad in the morning is the Tesla app to see how the solar yield is looking! Looking at Met Office and asking Amazon smart speaker for weather forecasts tends to be rough and ready and of course doesn’t alter anything a jot as to what we will actually get that day! My best yield days were 24th May and 4 June, both days yielded 51.5 kW/h and May as a whole produced 1,043.2 kW/h and June gave a total of 1,104.4 kW/h. At present, we have some scaffolding shading some panels on one roof as we were having slight problems requiring access to the panels to solve. Regards, Toodles.
- 2,783 Topics
- 65.6 K Posts
- 2,447 Online
- 7,187 Members
I'd be surprised if it wasn't a noise consideration. Ne...
By Majordennisbloodnok , 58 minutes ago
I've got a podcast recording scheduled this week where ...
By Mars , 13 hours ago
I’m a little late posting this, but it’s genuinely one ...
Ah, that makes sense when a combi is in place. The boil...
By Batpred , 16 hours ago
@bobflux Thanks, that gives me something to check the i...
By Paul1098 , 16 hours ago
For Powerwall calibration, avoid forcing repeated deep ...
By EnergyStorageTech , 1 day ago
By bobflux , 2 days ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 2 days ago
By bobflux , 3 days ago
By Andris , 3 days ago
By Papahuhu , 4 days ago
By Batpred , 4 days ago
By Rob of York , 4 days ago
By downfield , 5 days ago
