Prioritise PV output to DHW ?
I have ASHP and a PV array. (only been in for 3 months)
Even on dull days I am reading a +balance on the IHD.
I'm on Octopus "Cosy" and waiting for then to start FITT "connection".Â
The IHD , obviously (somehow?), knows which bit of power is from the PV array ............... is there a device that would
send any balance, when there is one, to top up the DHW if needed ?
Samsung 12kw ASHP, nine 415w PV panel array, upgraded radiators and DHW water tank (+ pumps etc). Two wireless zone thermostat controllers and Samsung MWR-WW10N
yes. myenergi eddi, marlec solar iboost, and others that I can't remember the names of, are devices that do exactly this. you will typically be able to get all your DHW in the summer and a fair chunk in the spring / autumn.
Although depending on your tariff you'll have to do the maths on whether its better to export, use it to power the ASHP for the DHW, or use the PV directly.
I actually have an Iboost in my garage that is FTAGH, (an older version that didn't play nicely with battery storage so I swapped it for an Eddi) if you are anywhere near milton keynes you're welcome to it.
Thanks for the reply. I'm in Worcester but ........
How much do you want and what is included ?
DOH .. I have just realised what FTAGH means 😊Â
@lenny yes, free - sorry, I can be guilty of too many acronyms. although if you are able, please make a red cross donation of what you feel its worth. Not the kind of thing that will get taken on freecycle and I don't want to take it to the tip whilst someone could still use it.
I have the iboost unit itself (which has to wired inline on the immersion heater power cable), and the CT clamp that goes on the meter cable. the CT clamp has a wireless transmitter to talk to the main unit.
exactly what is in these pics if you google it:
It was working when I took it out.
Â
Many thanks.
I would love to come and collect. How do you want to arrange this ?
Â
(donation to MS Society if that's OK with you, son has MS)
@lenny I'm of course absolutely fine with your choice of charity, particularly as it is personally relevant to you. I'll PM you.
- 2,776 Topics
- 65.5 K Posts
- 2,460 Online
- 7,183 Members
@editor That's a pity, but thank you for checking. I'l...
By ltron2 , 6 hours ago
@editor I'll start posting once I start in earnest.
By Paul1098 , 6 hours ago
My fifth heat pump book, Heat Pumps Explained, is out n...
By Mars , 14 hours ago
Just furkled Into the parameter menu. Found the master ...
By AgentGeorge , 15 hours ago
It's interesting that Norway with a much colder climate...
By Rob of York , 15 hours ago
Happy to add Scottish Power and the review 'dont touch ...
By JamesPa , 20 hours ago
By tomasmcguinness , 3 days ago
@mrkfm, I'd also suggest that whenever you're ready, st...
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 4 days ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 4 days ago
