Most efficient use of NIBE GSHP with Solar PV
Hi @derek-m
Thanks!
I totally understand about the battery (and the VAT side of things). It's just that I've got a SolarEdge single phase inverter and that system wants a high voltage DC coupled battery and there are only two that are compatible: LG Chem Resu Prime, or a SolarEdge StorEdge. I just don't have the money right now (about 5-6k for the LG, about 7-8k for the StorEdge).
In fairness, I could install any old AC coupled system. But that means I'll have to buy another inverter on top of the SolarEdge inverter I've already got. I know it's possible. And maybe it's cheaper and will work equally well. It's just not very elegant, so I'm biding my time, looking at all the things I can do, and then deciding.
Out of everything, the cheapest, simplest thing to do is to get an iBoost.
@windyinsancreed
We have a 4kW solar PV system which provides almost all our hot water from Spring through to Autumn. Even on cloudy days it can supply sufficient heat energy.
- 2,767 Topics
- 65.2 K Posts
- 3,253 Online
- 7,169 Members
By springswood , 1 hour ago
Others would have a different interpretation of the BUS...
By JamesPa , 1 hour ago
@old_scientist When I switched back to Cosy (bog standa...
By Toodles , 2 hours ago
I suspect it's a deliberate decisi...
By JamesPa , 3 hours ago
By Batpred , 3 hours ago
By bobflux , 12 hours ago
By Batpred , 19 hours ago
No, but the heat pump must be capable of delivering a S...
By cathodeRay , 4 days ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 4 days ago
