What a difference a week makes (And about 10 degrees or so!)
Taking a look at the COP from early January and comparing with this week just shows what happens to the COP when Jack Frost comes near. I readily admit that we are chilly mortals and not everyone runs their heat pump to provide the whole house with 22.5 degrees for most of the day and night. These charts are via the Homely Dashboard and show our Daikin 8 kW ASHP Monobloc. Regards, Toodles.
- 2,418 Topics
- 54.8 K Posts
- 364 Online
- 6,098 Members
R290 and Foundation Air Bricks
I am going around in circles. My property has foundatio...
By L8Again , 41 minutes ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Another good bout of cold weather should test whether t...
By JamesPa , 57 minutes ago
Thanks. The frogstar is the one Im potentially looking...
By JamesPa , 1 hour ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
Mine is the same as @skd i have luxpower inverters and ...
By IRMartini , 1 hour ago
@cathoderay Re defrost systems, i asked the engineer...
By MikeF , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@ashp-bobba I agree. I think I'll simplify the system j...
By Patch321 , 5 hours ago
Is it normal to use power from the grid when running off the battery?
I've recently had a Solis hybrid inverter fitted, with ...
By JohnnyB , 9 hours ago
RE: Reliable, easy to use home battery options
I have just had a my inverter and battery installed, ab...
By JohnnyB , 10 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 13 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 13 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 15 hours ago
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu Mine is similar. Is your house not getting...
By bontwoody , 17 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 17 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Sorry forgot about the three choices. It’s the 2nd one ...
By Davesoa , 18 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 19 hours ago
RE: Water outage in the the south-east
We think alike @editor ! All those bottles (and I expec...
By Toodles , 19 hours ago
@mrfield, welcome to the forums. Please go here and ...
By Mars , 21 hours ago
I did not hear back from the tech team. (Assume they ar...
By swwils , 22 hours ago
In the Home Assistant firmware the data points...
By F1p , 1 day ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 2 days ago
