£10 says there isn’t one
The pipe with the isolation valve with the blue handle, to what equipment does the pipe connect?
Can you send more detailed photos of the outside of the cylinder? I'm suspecting that it might be a thermal store...
It would appear that Hugh wishes to help, so rather than have too many 'cooks', I will leave you in his capable hands.
Best of luck in resolving your problems.
Posted by: @derek-mIt would appear that Hugh wishes to help, so rather than have too many 'cooks', I will leave you in his capable hands.
Cheers Derek 🤣 Just what I needed...
You are more than welcome.
I prefer to work through problems in a systematic and logical manner, particularly when the person seeking help is new to heat pumps. I suspect that having a number of forum members throwing different questions at them could actually be counterproductive.
It's going to be a difficult one to diagnose just off photos... I suspect that the ashp is batch charging the thermal store - that all needs re-plumbing if it ever stands a chance of working properly. Shame I'm basically the other end of the country.
This is one of the problems, you are arriving at conclusions without establishing the full facts.
- 2,136 Topics
- 33 Online
- 5,662 Members
By DavidAlgarve , 17 minutes ago
@ashp-bobba interesting insights. We also chatted after...
By Mars , 1 hour ago
I’ve not come across this brand, but then again I don’t...
Sanity check please. Battery storage and inverter sizing.
I had one installer essentially wanting to install a ti...
By AdamK , 11 hours ago
The gaps and holes have reduced on heat pumps over the ...
By dgclimatecontrol , 16 hours ago
Forum Handle: EGP01 Manufacturer: Samsung Model: 8K...
By EGP01 , 19 hours ago
By bontwoody , 21 hours ago
By Majordennisbloodnok , 22 hours ago
By Old_Scientist , 4 days ago
By robinlawrie , 4 days ago
By NJT , 4 days ago
By DavidAlgarve , 5 days ago
By Transparent , 6 days ago
By PatrickVito , 7 days ago
By Mars , 7 days ago
By Tim441 , 1 week ago
