Samsung ASHP gen 6 not heating when DHW set to forced
Posted by: @nearlynaughtI'm really surprised though because we have used forced since moving in and always had hot water and heating, its really confused me.
The installer may have changed the default, see the manual extract below.
- 2,102 Topics
- 46.2 K Posts
- 104 Online
- 3,388 Members
Thanks @toodles for the update. My PW3 is due to be i...
By Old_Scientist , 13 minutes ago
By Lucia , 1 hour ago
By Brendon Uys , 4 hours ago
By JamesPa , 6 hours ago
By Scalextrix , 7 hours ago
By ASHP-BOBBA , 23 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
