Samsung ASHP gen 6 not heating when DHW set to forced
Posted by: @nearlynaughtI'm really surprised though because we have used forced since moving in and always had hot water and heating, its really confused me.
The installer may have changed the default, see the manual extract below.
- 2,104 Topics
- 46.3 K Posts
- 155 Online
- 3,393 Members
The information in this site is very helpful when consi...
By skyefarmer , 34 minutes ago
By Toodles , 11 hours ago
By Lucia , 14 hours ago
By Brendon Uys , 17 hours ago
By Scalextrix , 19 hours ago
By ASHP-BOBBA , 1 day ago
By downfield , 4 days ago
By Sune , 4 days ago
