Samsung ASHP DHW on - 'Heat' setting off - should central heating radiators still be permanently on?
Hi,
We are new to ASHP tech. We have a Samsung ASHP HT Quiet 8KW - are our radiators (central heating system) supposed to be operating when 'heat' has been turned off on the Gen 6 Samsung control panel and only DHW is set to on in standard mode?
P.S. DHW on the Samsung Gen 6 control panel is set to a maximum of 47°c to heat up our immersion water heater.
Posted by: @horneHi,
I wouldn't have thought so unless
It's residual heat from when they were supposed to be on or
It's very cold and frost protection has kicked in
Can you give more info please about the symptoms observed and how often under what conditions?
Hi James,
Thank you for replying. Please bear with me as the additional info may be useful. The outside temperature was between 9°c-11°c during both tests
We had been heating our immersion water heater from our AC battery (fed by solar panels) as we were getting up to 24.6 KwH on good days from August to early Oct. The ASHP was installed in early Sept so I asked the installer to set the Samsung DWH to off on the control panel - I had only just got a reasonable understanding of our solar system, AC battery, Harvey and Eddi!
I set the Samsung control panel ‘heat’ temp to 19°c (central heating), DHW setting still off. I was made aware that the radiators weren’t supposed to be hot to touch and that it is best to keep the ASHP running for most of the day.
I did take a reading off the radiators - when the Samsung room stat recorded 19°c - 20°c the rads were around 23°c-25°c - measured with an accurate digital thermometer.
The first time I turned on the ASHP’s DHW (set to 50°c) whilst the central heating was on (‘heat’ temp setting for central heating at 19°c) we noted that the radiators were much hotter than they had been during the past few weeks (barely luke warm at 19°c heat setting and DHW off). I measured the rads to find they were 37.4°c whilst the DHW was operating. The Samsung control panels room temperature went up from 19°c to 24.6°c. The COP reading went from 4/5 down to 2/5.
A few days later I decided to turn off the central heating altogether for a few hours and then turn on the DHW, it was 9°c outside. I set the DHW max temp to 47°c (standard) for the test (see pic). The radiators were stone cold. The immersion was only around 20°c before I activated the DHW. Once again the radiators came on - ‘heat’ setting on the Samsung panel was greyed out - definitely off (see pic). When the Samsung control panel was showing DHW water temp of 40.6°c I measured the radiators with the same thermometer and recorded 34.6°c (image attached).
OK that helps. So as I understand it with ch turned off on the Samsung controller, rads get hot when you heat the dhw from the Samsung, but do not get hot when you heat the dhw from another source?
The first thing that comes to mind is a faulty/stuck/incorrectly plumbed/incorrectly wired diverter valve. This valve should ensure that the flow from the hp goes either to the rads or to the dhw tank but never to both. Have a look and a feel of pipe temps and check it's actually a diverter valve not a regular 3 way valve!
There are other possible explanations but that is the simplest.
James,
Thanks. The rads don't get hot when I heat the DHW from another source. I will check the installation - I do remember being told during the installation that one of the valves had to be kept permanently open (reason not given to me) which makes me wonder if this open valve might be the culprit, though my knowledge of plumbing is very basic.
- 2,775 Topics
- 65.4 K Posts
- 2,017 Online
- 7,180 Members
I'd rather be like this, than answering all th...
By Singlespeed , 1 hour ago
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 5 hours ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 7 hours ago
This just might need a rebuttal (possibly marginally mo...
By cathodeRay , 9 hours ago
@downfield I just checked this morning and OE just r...
By Papahuhu , 9 hours ago
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 24 hours ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 1 day ago
@mrkfm, I’m definitely not trying to put anyone off get...
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 2 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 3 days ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 3 days ago
Depends on what controls the pump! Thats the whole poi...
By Old_Scientist , 4 days ago
