R32, "optimum" delt...
R32, "optimum" delta T
2 Users
1 Reactions
(@madbilly)
Topic starter   [#2206]
Hi everyone,
I heard on the podcast recently that Daikin have changed to a 10C delta-T, and that this could reduce the flow rate needed which has intrigued me as I think our house is pipework limited (also heat pump power output limited but that's another story). I then read around a bit and saw that natural refrigerants can operate with a much larger deltaT than synthetic refrigerants like R32, e.g. R290 can operate happily with more than 10C deltaT I believe and CO2 (R744) actually needs a very large deltaT to operate effectively.
This made me wonder, what's the optimum deltaT for an R32 heat pump? I see most default to 5, Daikin just started using 10, and I'd read but without explanation that 8 is the magic number. I'm sure there's a good scientific calculation for this, something to do with PT curves?
Cheers 🙂
 robl
(@robl)
There’s no definitive magic deltaT for a heatpump, just pragmatic ‘generally optimum’. If you put more power into the water pump, the deltaT will reduce, and so then does the refrigerant gas-liquid transition temperature, making the heatpump more efficient.  This lower deltaT requires a faster water flow though - so the pump needs more power.  There’s an overall minimum power - and it’s generally found somewhere around deltaT=5 ish.  If your pipes are thin, it’s likely higher.
(@madbilly)
In our case the pipe run for the heat pump is short and large bore to a heat exchanger, so it's a bit more complicated. Interesting that a smaller deltaT is more efficient, I had thought that a higher deltaT would be more efficient, because it would mean the water was extracting more energy from the refrigerant per m3 of flow. Anyway, for us I think it's irrelevant as I don't think our Midea heat pump allows the deltaT to be changed, it seems to be fixed at 5C.
