Pleurococcus on my fins
Here in Somerset it is seldom dry and I've begun to notice that our heat pump fins are turning a bit green. This is pleurococcus and I'm sure it will reduce the efficiency a bit. https://herbaria.plants.ox.ac.uk/bol/plants400/profiles/OP/Pleurococcus
I'm thinking of spraying the fins with 'Patio Magic' which I use on the patio, fence and conservatory when they look a bit green. Any thoughts?
https://www.lovethegarden.com/uk-en/patio-magic
There are specialist cleaning solutions for heat exchanger fin coils. I would recommend you have the heat exchanger cleaned as part of a professional service. A diluted bleach solution would kill any biological growth, but needs to be carefully applied. Don't steam clean or apply under high pressure, e.g.: not with a pressure washer. Most ASHP coil fins ae aluminium, copper is much more expensive and used in commercial applications, it's naturally resistant to biological growth.
I’m inclined to agree with Ally. Don’t use anything abrasive. Have you tried a soft brush with soapy water? A mild vinegar solution could also work. I’d apply the solution to the fins with a spray bottle and let it sit for 10-15 minutes before rinsing it off with clean water.
- 373 Online
Out of interest, why did you buy the Aerona 3 R32, rath...
By GrahamF , 15 minutes ago
By Old_Scientist , 57 minutes ago
By DaveC , 1 hour ago
By Ubert767 , 2 hours ago
By bobflux , 4 hours ago
By benson , 5 hours ago
By bobflux , 7 hours ago
By Jonatan , 12 hours ago
By Batpred , 19 hours ago
By Transparent , 23 hours ago
By bobflux , 23 hours ago
By Toodles , 1 day ago
