Optimising ecodan ASHP
I think I’ve said it before but mine will cycle anything below 32C. The difference between flow temp and house temp is too small and your emitters can’t lose the heat the smaller that gap the more cycling you will get.
im using a similar amount 30-40 at milder temps 40-50 at sub zero
@gary thanks Gary, yes I saw that you said that before which is what made me wonder. Your explanation makes sense - I will keep an eye on it then to make sure it’s sticking to a max of a couple of cycles an hour, and probably leave it at 30.
That’s reassuring! Had a monster day of 70kwh last Saturday but it was v cold all day, lots of chores as it was Saturday and I didn’t set back overnight because it was so cold (don’t know if this is right approach or not but I didn’t want to risk getting into a death spiral)
- 2,775 Topics
- 65.4 K Posts
- 1,601 Online
- 7,180 Members
@mrkfm, I'd also suggest that whenever you're ready, st...
By Mars , 7 hours ago
I'd rather be like this, than answering all th...
By Singlespeed , 8 hours ago
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 12 hours ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 14 hours ago
This just might need a rebuttal (possibly marginally mo...
By cathodeRay , 16 hours ago
@downfield I just checked this morning and OE just r...
By Papahuhu , 16 hours ago
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 1 day ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 2 days ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 3 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 3 days ago
Posted by: @ian-s Could always use the money saved o...
Depends on what controls the pump! Thats the whole poi...
By Old_Scientist , 4 days ago
