My ASHP is not performing as well as I’d hoped: COP just over 2
@hcas - exactly so. I did read one other persons similar experience but the overshoot was lower if I recall correctly. I can only make this comparison because I have an electric meter just on the cable for the heat pump, but as it is not close the FTC unit I cannot connect an output from it to the FTC which would then replace the unit's own guesstimate with the metered value. This is what most people who have invested in metering will have done.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
Have been incommunicado for a while. Now back online and will revisit this thread asap.
@toodles No. But I wasn't forced there either and The King had nothing to do with my trip LOL.
Just when I returned I had no internet which has now been resolved.
- 2,102 Topics
- 46.2 K Posts
- 182 Online
- 3,388 Members
By JamesPa , 35 minutes ago
By Scalextrix , 46 minutes ago
And we have it: DESNZ are now investigating the feasi...
By Lucia , 4 hours ago
By ASHP-BOBBA , 17 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
