MCS consultation on amendments to PD rules
@jamespa Yes, the truth hurts ... (but silence kills 😐 ). I totally understand all your points, but I think the authorities need to know about the loopholes in regulations. Although, after two years of correspondence with tens of institutions and individuals, I now believe I am just wasting my time. The amenity of the public is of no importance to authorities.
@sentinam My neighbour is a builder! As far as I know they used some Governmental Grants Schemes, but the Scheme states they have no enforcement power! The condition for ASHP was NR30 day and NR25 night. Environmental Health confirmed NR39, but then they decided to support my neighbour's retrospective because obviously the councils want to avoid all the hassle of enforcement. Re. lawyers: one asked for £3000 to just read the case, two did not get back to me, one said that I may end up spending £10,000 to £20,000 with no result.
The ASHP is on rubber feet, but it is installed on the boundary of their house with the parkland behind our houses. I believe the 3.8 meters distance of the ASHP with the house makes the device work more vigorously. I also believe there is something wrong with the transformer/compressor because sometimes I hear horrible annoying noise similar to humming of fridges (but very annoying and very loud). The ASHP is also less than a meter from the boundary with my house and makes horrible buzzing noise even on warm and sunny days. So, no peace even in my back-garden.
I think the model is Mitsubishi PUHZ-W112VHA(-BS).
Posted by: @persephone@jamespa Yes, the truth hurts ... (but silence kills 😐 ). I totally understand all your points, but I think the authorities need to know about the loopholes in regulations. Although, after two years of correspondence with tens of institutions and individuals, I now believe I am just wasting my time. The amenity of the public is of no importance to authorities.
I guess the authorities will say that it's covered by nuisance law which they will saw is robust.
If you haven't already done so I would suggest you measure noise levels (from the ashp, make sure you exclude other intermittent noises) either 1 m in front of the most affected windows or inside if it is loud enough to hear inside, particularly in the bedrooms. Then compare to bs8233 or just post here. This will give a clue as to what chance you might have if you were to pursue it eg by making an escalated complaint to the council about lack of action by the eho.
For gbp15 you can buy a noise meter from Amazon which is good to about a dB down to 30dBA, anything below that is likely to be too quiet for any enforcement to be interested
Posted by: @persephoneThe ASHP is also less than a meter from the boundary with my house and makes horrible buzzing noise even on warm and sunny days. So, no peace even in my back-garden.
Are they heating on warm and sunny days, or is this for DHW only, or are they cooling (in which case did the planning consent cover cooling). If its DHW only then could you speak to them about when they heat their water?
Posted by: @sentinamAlso wonder if a free first half hour with a good planning lawyer might help.
If they have consent they have consent, the fact its retrospective is irrelevant. Unless they have violated a condition, or not done what it says on the plans then there is nothing that can be done in planning law unfortunately.
- 63 Online
@editor Not yet mine is still off. I have been monitori...
By TechnoGeek , 4 minutes ago
I think the problem you are having comes down to the un...
By JamesPa , 24 minutes ago
By Old_Scientist , 38 minutes ago
Like @pash44pump I would be interested in recommendati...
By Morgan , 2 hours ago
By cathodeRay , 15 hours ago
By ASHP-BOBBA , 16 hours ago
By dgclimatecontrol , 18 hours ago
By Lucia , 1 day ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
By HCas , 2 days ago
By jamespetts , 2 days ago
By GrahamF , 3 days ago
By immunity , 3 days ago
Just done your survey!
By Judith , 4 days ago
