Is it KISS or const...
Is it KISS or constant – weather compensation vs. set flow temperature?
6 Users
7 Reactions
(@cliffhanger)
Away at present. Hence the delay.  Will get back asap.
Cliff
(@cliffhanger)
Okay. I have setup the system using just weather compensation.   There is something called 'thermal blockade' on my smart controller which turns off the stat rather than turn it to maximum.
I'm going to video the heat curve but at the moment it starts at 18(20c) and runs to 45(-30).  -5c = 33c. The OAT is 10c and the system is stable at 19.5c.   I tried a lower curve but the pump cycled as expected, 25c is the lowest it will go.
What's struck me is how cool the rads are.  They don't feel they could warm anything!  But they do of course.  Now we are at the end of March the system's not going to be tested at lower temperatures which to me is the breaker.
To be continued
Cliff
Posted by: @cliffhanger
Indeed.  Its weird at first but you get used to it and actually it is more comfortable because the temperature gradients are less.
There is a school of thought pursued by some installers that having cool radiators leads to call outs (which is probably true).  Thus some installers force a minimum FT of 37, which is roughly the point at which radiators feel warm.  This of course increases the cost to the householder.
(@old_scientist)
We ran our radiations at anywhere between 30-35C over winter. At 30C I struggle to tell they are on. If I place my face over the top of the radiator, I can just about feel warm air convecting on my face. At 32C I can feel they are warm to the touch, and at 35C they are (relatively) positively hot!
I still walk around touching the radiators to see if they are on - I just need to trust the room thermostat, which doesn't lie.
(@grantmethestrength)
I had to laugh at this as I do exactly the same thing, I read on here someone explain it well, the body is running at 36c so anything less will feel cold. As I explain to friends it is actually magic that heats my house!
This post was modified 5 months ago by Mars
Kind Regards
Si
Grant Aerona3 13kW
Sigenergy 10kW Inverter
16kW Sigenstor battery
(@cliffhanger)
Hi
Just as an aside.  My system is heating only.
What is the best way of turning a weather compensation setup off in the summer?   I thought of turning the stat back on to its lowest temp, in this case 10c.  Won't go any lower.
Or setting the heating curve to its lowest?
Cliff
@cliffhanger Mine has a 'space heating off' setting!  Otherwise turn down thermostat if you have one and it's set up to call for heat
This post was modified 4 months ago by JamesPa
Page 3 / 3
