Getting the best out of a heat pump - is Homely a possible answer?
Posted by: @bensonI have found a QR code on top of the indoor control panel but this doesn't seem to be doing the trick either unfortunately.
I think that QR code is to download the app SmartHome or whatever it is called). Once you have the app, you have to pair it with the wired controller (which becomes an access point) and your smartphone via wifi. I think it does give you control, but somewhat limited.
@cathoderay thanks I have just figured it out. You need to go to the WLAN setting on the Clivet (or midea) control panel and turn on. The control panel then becomes discoverable. I now have the app up and running. It does say that in the instructions in fairness. That'll teach me to read them properly 😆
The functionality seems fine, so I think this alongside home assistant may work well for us. I'll probably start testing it when it gets colder (and temporarily unplug the homely) to see if I can get the heating working well just by setting the curve and no thermostat, as has been suggested.
Posted by: @bensonThat'll teach me to read them properly
It took me more than a few goes as well, plus some help from this forum!
Weather compensation curve properly tweaked is the way to go (or if not, the best starting point - I ended up adding an 'auto-adapt' script that takes into account the indoor air temp as well, basically bump up the weather curve a bit when IAT below what it should be). Best done when the heating is on, which hopefully it isn't on Midsummer's Day!
@cathoderay how did you get a script to run for that- did you integrate the midea control panel within HA?
Posted by: @bensonOnce anyone has all their money, the only leverage you have is the threat of leaving them a bad review. I didn’t expect anything more from MCS or NAPIT to be honest, than we got.
It's good to be reminded of this! Somehow we think that grant funded works are exempt from this general self-protection principle which applies to all other building work. They aren't.
The difficulty with heating works of course is that, unless they are done midwinter, you don't get to test in ernest for several months after they are completed. However that doesn't stop you checking for obvious poor workmanship, missing documentation etc and withholding payment or grant sign off until that is fixed.
Back on topic, with our clivet I now have everything set up for pure weather comp when the heating season kicks in. Our homely is uninstalled and back in the box for the time being, and will hopefully be an interesting comparison.
I have found a way of automating slight adjustments to the curve as well for any under and over shooting, within HA so I will see if that works as well.
Posted by: @bensonI have found a way of automating slight adjustments to the curve as well for any under and over shooting, within HA so I will see if that works as well.
I missed your 22nd June post on this. I am sure it can be done in HA as well, but I use a standalone script that runs once an hour, checks the IAT and moves the weather curve up or down a bit if the IAT is too low or too high. I've posted the script before, but for ease of reference here it is again.
- 2,171 Topics
- 47.8 K Posts
- 19 Online
- 5,744 Members
3: For retrofits, installers have no clue what existing...
By Old_Scientist , 32 minutes ago
RE: MCS certificate SCOP vs real-world performance
MCS SCOP 3.84 (design LWT of 47C) Actual real world S...
By Old_Scientist , 48 minutes ago
@jamespa installer said today "Yeah unfortunately thay ...
By AdamK , 1 hour ago
Many thanks for contacting the brand manager, that's ve...
By RHH1 , 1 hour ago
Thanks, that might explain the when, and possibly the w...
By cathodeRay , 2 hours ago
How it does it's job is something of a mystery although...
By Abernyte , 4 hours ago
Yes I was thinking of outdoor, IP65 batteries with buil...
By Temperature_Gradient , 8 hours ago
@jamespa Thanks. Yeah any adjustments Ive made at pr...
By cliffhanger , 11 hours ago
By GrahamF , 2 days ago
By bontwoody , 2 days ago
By Scalextrix , 2 days ago
By cathodeRay , 3 days ago
By Paul G , 4 days ago
