General advice on ASHP please
I would suggest that a thermal camera should also be used indoors as well as outdoors. In this case look for cold spots, in particular in ceilings and floors as well as the walls and windows.
- 60 Online
Seems a lot of work with hit or miss results and potent...
By dgclimatecontrol , 27 minutes ago
@dgclimatecontrol I have no intention of removing the...
By Morgan , 34 minutes ago
By Transparent , 37 minutes ago
In the FT today, a report that heat pump take up in Eur...
By Mike Patrick , 38 minutes ago
@tim441 As you say Tim, very difficult to quantify any ...
By Toodles , 2 hours ago
@abernyte Our heating has come on twice in the last wee...
James, I would not question your findings and realise t...
By Toodles , 3 hours ago
By HCas , 3 hours ago
By jamespetts , 4 hours ago
By jamespetts , 5 hours ago
By HCas , 24 hours ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
