Effects of Low Loss Header (LLH) removal - Initial findings
Small update on the findings from the data
My calcs say that the days at 1 and 2 degrees were about 25% and 20% more efficient without the LLH. However I would note these results are estimates for with the LLH as it never got that cold for the time it was installed. However the data looks fairly solid.
- 2,102 Topics
- 46.2 K Posts
- 72 Online
- 3,388 Members
@skyefarmer great you located the source of the issue a...
By Mars , 2 hours ago
By ASHP-BOBBA , 11 hours ago
From what you say about the radiators upstairs it does ...
By JamesPa , 17 hours ago
By Mars , 20 hours ago
By Mars , 23 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
By Aventus Eco , 4 days ago
By Tim441 , 5 days ago
