Ecodan help
3 Users
0 Reactions
(@mikefitz)
Topic starter   [#482]
Can anyone assist me in setting the hotwater unit settings on my Ecodan 14
Should I be using "FLOW" or "CURVE"?
What is an ideal Flow temperature?
What should the Temperature Increment be set at?
Thanks
@mikefitz,
Not sure what you mean.  DHW just uses a target temp, independent of how you set the heating.  You can then choose Eco of Normal, which affects how quickly it heats up.
For the increment, I assume this is the temp drop before it starts re-heating the tank?  I was advised by the Mitsi engineer to leave it on 10 C  if you have water heating on constantly because otherwise, because of where the tank temp sensor is, the DHW would kick in every time you wash your hands. Drop it to 5 if you heat your water once or twice a day only via the timer (what I do)
(@mikefitz)
@kev-m thanks greatly for the reply
I was referring to the Unit Settings on the remote controller.
I’ve played around with it so much that I cannot remember the default settings
Posted by: @mikefitz
Thanks
Hi Mike,
I think that you will find that flow and curve relate to the central heating control, not DHW.
If you have a copy of the 72 page manual for the FTC5 controller then go to section 7 (page 40) and follow the instructions. Raise any questions that you are not certain about.
(@mikefitz)
@derek-m
Looking at the Unit Settings again I think you are correct.  It has "Set tank temperature " at the top and I just assumed that the lower section was linked to the hot water but I can see that I was wrong.  Its referring to the heating flow.  Many thanks
