Does your heat pump calculate and provide you with a COP figure?
Hello Pkham, for comparison only (and I don’t know how typical our performance figures may be); we have a Daikin EDLA08 8 kW ASHP but the DHW is serviced separately by a solar / grid powered Sunamp Thermino ep210 unit, I have been tweaking our system in a 4 bedroom semi of 98 sq. metres with good insulation and recently we have fitted a Homely smart controller to the ASHP. With temperatures of 10 - 12 degrees as experienced of late, our pump is just ticking over at approx 0.5 kW/h to keep us at 22.5 degrees throughout the house 24/7. We have Octopus Cosy tariff and this means we are paying approx. £2.00 per day. Our DHW consumes between 3.5 and 4.5 kW/h daily; this adds up to 75pence daily. So for the last week at least, we are running at a cost of approx. £2.75 per day plus the despicable ‘standing charge’, we are fully electric so do not have to pay gas standing charge as well. At the end of November and the beginning of December when temperatures hovered around -2 degrees, we were using approx. 318 kW/h per week for heating, cooking, lighting, domestic appliances and DHW - costing a total of £54.11p. Our hot water needs are met by the cold mains feed passing through the Sunamp heat battery (rather akin to a gas boiler’s combi arrangement but so much cleaner). As a result, we don’t need to have anti-legionella cycling; do you have a setting to raise your water to 60 degrees C periodically? Regards, Toodles.
Our Ecodan data is available on a daily update on the controller and gives a running total for a month or year. However If you want daily COP figures you need to write down the daily running totals and do a bit of maths, or it would appear you can get a 3rd party program WHICH can access the ecodan stored data.
The MELCloud App which is free from Mitsubishi will provide remote control of the HP Via a phone and also provides daily, hourly or yearly performance data but even so, a bit of maths is needed if you want to work out daily COP.
ENERGY CONSUMED December 23
In the above MELCloud graph I have written daily average Ambient temperatures which helps to show the increased energy needs we needed in December depending on Outside Ambient temperature changes.
I think it’s very useful to see that a cold spell can be very energy hungry compared to a moderate 10C ambient.
ENERGY DELIVERED December 23
Once a system is set up it is perhaps only necessary to see a monthly COP. But we have found that when we are tweeting certain settings a comparative daily COP is useful… it’s not until you see the COP for a particular day/OAT that it really means anything to the new settings. In the above graph I’ve added the daily COP values we have had for each day.
We have tweaked our settings at particular days and seen COP fall as well as rise as can be seen.
@pkham I am not a Midea owner, but if I am reading your screenshot correctly you are running it to a fixed temp output of 41° not a variable output WC curve - the graph is rather simplified so it is hard to draw definitive conclusions. I presume you meant your house is 226 sq m, not ft, which is a fair size to heat and reflected in the spec of a 16kW heat pump. I would expect your system to have been designed to have an output temp of 45-50° at -3° and the unit sized accordingly. If you are adjusting the WC curve but not actually running it you might have a shock when you change over to it in the middle of winter!
Daily whole-house electricity costs are not much use here as we have no idea of your lifestyle and appliances, if you want to get into the nitty gritty of consumption and output then you need to gather figures for both.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
Rate the quality of your heat pump design and installation
3 months ago
Vaillant Arotherm yeild and COP readings
11 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Viessmann Vitocal 250-A in the UK
1 year ago
Slash Your Heat Pump Bills Overnight
1 year ago
- 2,131 Topics
- 18 Online
- 5,656 Members
@transparent - as a matter of interest whats 52V for? ...
By JamesPa , 45 minutes ago
By dgclimatecontrol , 5 hours ago
By PatrickVito , 10 hours ago
By Mars , 11 hours ago
By Tim441 , 1 day ago
By Tim441 , 3 days ago
By Abernyte , 3 days ago
By Eliuccio , 5 days ago
By Scalextrix , 5 days ago
By Mars , 6 days ago
By Scalextrix , 7 days ago
