Designing ASHP system using the Freedom toolkit spreadsheet
@hughf - it is definitely on the cards, but I haven't quite got to the Oscar Wilde moment yet ('either the PHE goes, or I go') as I am still a bit in favour of the pros of separating the two circuits, and now we have warmer weather, it is less easy to investigate the cons, losses due to the PHE. Mine also got hampered by the installer's plumber's well intentioned but unwise habit of reversing the flow, ie removing the contraflow by rotating the pump through 180 degrees, in a bid to improve radiator heating (they tend to be too cold, even with adequate primary flow temps). I think this is most likely inadequate circulating flow rate, despite the pump being on its max flow rate setting, water in effect stagnates in the rads and cools down, and it will be easier to fit a higher flow rate circulating pump if the two circuits are separate. There is also the question of the adequacy of the circulating pump in the heat pump, if it has to maintain a fast flow round all the rads, rather than just the PHE.
Posted by: @jezzaf@hughf Hi.. just read your comment and the last line caught my attention and if I understand you correctly .. so many years ago I did a self install of a Trianco Active Air Heatpump .... it was a rebadged chinese made machine anyway the compressor failed I can't now remember if it was in warranty or just out. The point was that as I was not an "approved installer" the manufacturer "Trianco" would not even talk to me or assist in any way. Ended up scrapping the unit and now happy with air to air. But moving to G2 listed Farmhouse in Somerset in two weeks so its full circle for me back to oil 🙂
That's unfortunate, but the nature of the beast with any sort of refrigeration in a domestic environment over here. Look at the US, HVAC tech's everywhere, perfectly capable of changing all the parts inside your average split ac/heatpump unit. Compressors, 4 way vavles, expansion valves, filters, all available from the spares suppliers or kept on the van.
To be honest, I like to write down my tech at a reasonable rate, so if I can get 10 years out of something that costs £3k, I'm happy with that. I wouldn't expect any issues within 10 years, perhaps a regas, but that's easy enough for anyone with F-gas to do.
- 2,764 Topics
- 65.1 K Posts
- 3,748 Online
- 7,169 Members
I think not but have now added the cloud coverage weath...
By Batpred , 8 hours ago
@judith Thanks very much for this! My room by room calc...
By jon , 12 hours ago
RE: Vaillant Arotherm Plus 7KW need a service on it
I think that is outrageous even if I suspect not unique...
By Batpred , 12 hours ago
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 16 hours ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 22 hours ago
Posted by: @jamespa At this point its probably worth...
By Rob of York , 24 hours ago
@batpred thanks for getting a copy. Appreciate the supp...
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 2 days ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 3 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 3 days ago
Thank you @trebor12345
By rgabor , 3 days ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
By Toodles , 4 days ago
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 4 days ago
