Derek’s heat pump modelling tool
Hi Kev,
I have eventually completed the modelling tool, so please feel free to take it for a test drive to see if any of the wheels fall off. I have set the initial operating parameters to those you supplied, along with the 15% increase in heat demand that you thought applicable. I would suggest that you read the notes on the first sheet, which explains how to initially set the operating parameters and what scenarios it may be possible to investigate.
For those of you who have a 14kW Ecodan of the same model, but are not Kev, you will need to set the initial parameters for your particular system before using the modelling tool.
For those of you who have an Ecodan, but not the 14kW model, but are conversant with Excel Spreadsheets, it will be necessary to change the manufacturers data for the 14kW unit, to that for your particular model.
For those of you who do not have an Ecodan ASHP, you should still be able to see the possible effects that changes to desired indoor air temperature setting, extra insulation, or larger heat emitters may have on your system.
Please provide feedback, good or bad, should you deem it appropriate. All donations to the 'help make Derek M a rich gentleman fund' gratefully accepted. 😀
post moved
Derek,
I think that the model represents my system very well. At an outside temp of 2C, your model says my ASHP will use about 1.8kW to heat my house to 23C at a flow temp of 35C. That's very close to what I'm seeing. I'll post some graphs in a bit.
Using the playroom and my house and outside temps for 21/11/21, the model predicts I'll use 41.3kWh using the radiators and heat loss figures I told you. I actually used 42.2.
The house was too hot at 23.5 so I dropped the flow temps. On 22/11, again, the model is very close at 32 predicted/33 actual. Interestingly, the ambient temps were very close on both days and dropping from 23.5C to 21.5C made a big difference to the energy used.
I'll try some other days. It would be interesting if the other Ecodan owners had a go.
Good work!
I will give it a go as we have a very similar system....just need to get my head around Derek's sophisticated spreadsheet!
Posted by: @hjdI will give it a go as we have a very similar system....just need to get my head around Derek's sophisticated spreadsheet!
Hi HJD,
It is fairly simple to use, if you read the instructions under 'Notes', anything that you don't fully understand then just ask. The main thing is try to get your heat demand and heat emitter sizing as accurate as possible.
- 2,773 Topics
- 65.4 K Posts
- 3,041 Online
- 7,175 Members
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 7 hours ago
And then you look at US electricity prices and weep.
By bornagain , 9 hours ago
Depends on what controls the pump! Thats the whole poi...
By JamesPa , 14 hours ago
By Old_Scientist , 1 day ago
@renewables345 I would say if it a new build it’s no mo...
By Aventus Eco , 2 days ago
By Jimcub , 3 days ago
By Prunus , 3 days ago
