A few pictures of where we are at the moment - Need to tidy up those battery wires and ethernets (they are way too long)
Very tidy Midea installation
@batalto, looking good.
New tank is in the loft - it fits!
@batalto, excellent. Do you have any photos?
Guys came back today to finish off the lagging and tidy up a few areas. Changed out the expansion tank from 18l to 25l. Not really a lot else to see except the services cupboard with all the meters and what not
Boiler cupboard (boiler doesn't work anymore!) - quite messy with old and new pipework. Anything unlagged is old (I assume?!)
Looks good. Why did you keep the boiler?
Just left it for the time being. I'll probably get rid next year after we've had the winter. It's all disconnected and just a lump on the wall for the moment
Solic now replaced - all working and diverting now. A bit of extra free energy for the tank
Next step - RHI application has been placed. Awaiting the process
Still awaiting contact by JL Phillips to arrange to carry out the full technical survey having accepted their quote.
- 2,104 Topics
- 46.3 K Posts
- 95 Online
- 3,393 Members
The information in this site is very helpful when consi...
By skyefarmer , 4 hours ago
By Toodles , 14 hours ago
By Lucia , 17 hours ago
By Brendon Uys , 20 hours ago
By Scalextrix , 22 hours ago
By ASHP-BOBBA , 2 days ago
By downfield , 4 days ago
By Sune , 4 days ago
