ASHP and Tado
Posted by: @gfletcher@morgan Brilliant - thanks, I'll look at the curve settings.
Hi Gavin,
Obviously you need to set the slope of the weather compensation to the requirements of your particular home. I would suggest that you start with the following settings and then fine tune as necessary.
Cold end: LWT of 50C at amb. of -5C.
Warm end: LWT of 25C at amb. of 20C.
The indoor temperature will probably change very slowly, so monitor your system for quite a number of hours and let it stabilise before making any adjustments.
I hope that this helps.
- 19 Online
By jamespetts , 29 minutes ago
By jamespetts , 37 minutes ago
By ASHP-BOBBA , 2 hours ago
By JamesPa , 3 hours ago
By Tim441 , 6 hours ago
By Toodles , 7 hours ago
By Transparent , 8 hours ago
By HCas , 11 hours ago
By jamespetts , 11 hours ago
By jamespetts , 12 hours ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
