ASHP and Tado
5 Users
2 Reactions
Morgan
(@morgan)
@gfletcher
That’s the weather comp setting but you have to set the curve in settings.
(@gfletcher)
@morgan Brilliant - thanks, I'll look at the curve settings.
Morgan
(@morgan)
@gfletcher
you’re welcome.
Posted by: @gfletcher
Hi Gavin,
Obviously you need to set the slope of the weather compensation to the requirements of your particular home. I would suggest that you start with the following settings and then fine tune as necessary.
Cold end: LWT of 50C at amb. of -5C.
Warm end: LWT of 25C at amb. of 20C.
The indoor temperature will probably change very slowly, so monitor your system for quite a number of hours and let it stabilise before making any adjustments.
I hope that this helps.
Page 2 / 2
