Jokes and fun posts about heat pumps and renewables
@majordennisbloodnok That’s OK as long as the ‘Terminological Inexactitude Filters’ don’t get clogged up every day. Toodles.
- 92 Online
Seems a lot of work with hit or miss results and potent...
By dgclimatecontrol , 47 minutes ago
@dgclimatecontrol I have no intention of removing the...
By Morgan , 54 minutes ago
By Transparent , 57 minutes ago
In the FT today, a report that heat pump take up in Eur...
By Mike Patrick , 57 minutes ago
@tim441 As you say Tim, very difficult to quantify any ...
By Toodles , 2 hours ago
@abernyte Our heating has come on twice in the last wee...
James, I would not question your findings and realise t...
By Toodles , 3 hours ago
By HCas , 4 hours ago
By jamespetts , 4 hours ago
By jamespetts , 5 hours ago
By HCas , 1 day ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
