Replacing mains water with well water
Following on from a topic on heating @editor asked for some info on our well
We have mains water on the street, but Scottish Water demanded a huge connection fee, which I wasn't prepared to pay, plus water charges are high. So prompted by our ground works team lead, I looked at a borehole / well.
Made contact with a couple of companies, but eventually settled on GRC Aquatec, they insisted a water deviner came first. He arrived and did his thing. 10 to 15mins later, said, we will drill here, then wondered off up our hill and came after another 10 mins. Told we had 4 good underground streams feeding our well. Then got his pocket watch out and it spun over the drill location. He then told me they will hit water at 15m, but that is just a stream, at 34m will be the main water.
A month later the drill team came, water hit at about 14m, final drill depth was 36m. However drilling was mostly through sand, some clay and a bit of sand stone, so we needed 30+m of steel liner, normal is a few meters of steel the rest in plastic, so bigger bill.
Getting the water suitable for consumption, is a turbidity back wash filter, with a added stuff to get rid of iron, a 10 and 5 micron filter and a UV filter. The well has a submersible pump and that feeds a 100L accumulator. Pump is switch on and off via a simple pressure switch on the accumulator.
We service it once a year.
Was it a smart move
For me, yes. Scottish Water add chlorine to water and I hate the taste it leaves. We have pure treated water, tastes great. It's hard compared to the soft water from the normal tap. So we have to descale the kettle once on a while, but that's ok.
We now have a battery and generator, so are fine in a power cut.
Costs (2021)
Drilling and liners £5k
Filter system, 40L/h pump and accumulation vessel, all manhours to install, testing water, almost another £5k.
So £10k, but claimed the vat back so £8k.
I too have a well, but this one is a c1500 drystane well around 30 feet deep. It is fed via underground stone drains over a considerable area. It holds around 900 gallons continually and can refill from near empty in around 45 minutes. The water is beautiful and soft and was our main supply until the water main arrived some years ago. Yes, Scottish Water do chlorinate but that I can filter out at point of use. We switched to gain mains pressure as pumping to the tanks in the loft to get sufficient head for a gravity system was too limiting.
The company that did the borehole were expecting us to have a low volume pump and overhead storage. The accumulator vessel allows us to have a steady supply presssure of 2.5bar or more if we want. So we have invented cylinder and everything in the house is a good flow rate.
- 2,762 Topics
- 65.1 K Posts
- 1,706 Online
- 7,169 Members
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 53 minutes ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 7 hours ago
Posted by: @jamespa At this point its probably worth...
By Rob of York , 9 hours ago
@batpred thanks for getting a copy. Appreciate the supp...
By Mars , 18 hours ago
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 23 hours ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 2 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 2 days ago
I’m really liking reading through this thread and the r...
By Judith , 2 days ago
Thank you @trebor12345
By rgabor , 2 days ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 3 days ago
My Adapt is finally installed and running! Almost a yea...
By tomasmcguinness , 3 days ago
