What do we need to know before installing a heat pump?
S I take it that you said: ‘Tanks, but no Tanks.? This sort of inflexibility is going to give MCS a bad reputation — err…. Oh Yes, they have already!
Very good. And yes it was a quick goodbye to BG.
@davesoa Though our 99 litre tank was in good order and only 3-4 years old (replaced by BG when they couldn’t locate the reason for a fault in the boiler whilst under service contact - you know the one, it is called an annual service and is carried out every 18 - 20 months!), it was large enough for our washing needs. Of course MCS wouldn’t accept this and in any case, the standard or slimline heat pump HWT would not fit in our space when they hold 210 litres! Fitting the Sunamp Thermino ePV 210 was a very neat solution for us. Summer consumption averages 2.5 kW/h per day and in colder weather, this figure was 3 - 3.5 kW/h per day powered via our Eddi rom the PV. I’m very pleased with the unit and it fits in the airing cupboard! ‘Smart tanks’ look to me like a sledge hammer to crack a nut with all that plumbing, pumping system, sensors and controls! (No space except possibly in the loft if the trap were enlarged first…) Regards, Toodles.
Posted by: @davesoaFollowing my failed attempt to get a HP installed earlier this year I decided to have a heat pump ready unvented hot water tank installed. My showers work wonderfully now and water is being heated via an iBoost every day from the PVs. My plumber took great care to select the right tank. I thought I’d try British Gas and see if they would quote for a heat pump as they offer a guarantee of performance. They will, but only on the understanding that they would want to rip out the newly installed tank and put theirs in instead. They weren’t interested in discussing why they take this approach or what might be wrong with the tank.
I am guessing that they use the hp manufacturers pre plumbed cylinder to ensure that their rookie plumbers can't completely screw up.
@toodles We have (now) a World Heat air source compatible unvented hot water cylinder with all the necessary changes to pipe work that a HP installation would require. If it remains an absolute MCS requirement to have it replaced, and it’s not just BG being awkward, then I’ll just forget about a heat pump.
- 2,177 Topics
- 47.9 K Posts
- 26 Online
- 5,748 Members
@jamespa yes I guess. But surely not everyone is buying...
By AdamK , 6 minutes ago
General Ignorance, the universal enemy in so many ways!
By JamesPa , 49 minutes ago
High thermal mass, plus that chart is very zoomed in. I...
By cathodeRay , 2 hours ago
RE: Preparing for 2nd winter in new build house.
Yuch! So that's basically just an on/off control. I...
By Transparent , 3 hours ago
Good day everyone. I'm new here and have a few question...
By Edin67 , 7 hours ago
Welcome to the forums. Was there any formal in-person...
By Mars , 9 hours ago
@transparent Morning. Just put a lengthy post on the AS...
By sbm74 , 9 hours ago
RE: MCS certificate SCOP vs real-world performance
That may be contributing to lower than expected SCOP. ...
By JamesPa , 19 hours ago
How it does it's job is something of a mystery although...
By Abernyte , 1 day ago
Yes I was thinking of outdoor, IP65 batteries with buil...
By Temperature_Gradient , 1 day ago
@jamespa Thanks. Yeah any adjustments Ive made at pr...
By cliffhanger , 1 day ago
By GrahamF , 3 days ago
By bontwoody , 3 days ago
By Scalextrix , 3 days ago
By cathodeRay , 4 days ago
By Toodles , 4 days ago
