Is it possible to recoup the investment on batteries?
EVM has done a video on his home battery costs, thoughts?
@ken with my batteries and current prices I'm expecting to have them more or less payed back this year. When I installed them it was 10p per KW. Now I'm on go and also filling them at night to use in the day the numbers just are a no brainer
- 2,104 Topics
- 46.3 K Posts
- 34 Online
- 3,393 Members
By Toodles , 19 hours ago
By Lucia , 22 hours ago
By Brendon Uys , 1 day ago
By Scalextrix , 1 day ago
By ASHP-BOBBA , 2 days ago
By downfield , 4 days ago
By Sune , 4 days ago
