How to keep SunSynk batteries warm?
l too had the same problem. I have got a 3.6kw Sunsynk inverter and a single 5.12 ip65 battery installed in my loft. During the cold snap my battery cut out and refused to charge. I had an old "memory foam" mattress topper that I was in the process of throwing out. I cut the mattress up and made an insulation jacket that I'll leave on the battery for a couple of months in the winter. I also have a small fan heater connected via a smart switch so I can use Alexa to turn on the fan if it is particularly cold in the loft. The fan is only on warm and about 3 feet away from the battery so as not to cause a hot spot or overheat the battery. This works well for me.
- 23 Forums
- 2,098 Topics
- 46.2 K Posts
- 36 Online
- 3,385 Members
By JamesPa , 1 hour ago
By Damon Blakemore , 8 hours ago
Hmm Before doing that I would want to be certain that...
By JamesPa , 13 hours ago
By Majordennisbloodnok , 13 hours ago
By downfield , 1 day ago
By Sune , 1 day ago
By Aventus Eco , 3 days ago
By Tim441 , 3 days ago
By abam48 , 5 days ago
By Toodles , 5 days ago
