National Grid ESO peak hour rebate
I got about £8 for the 23rd, £12 for the 24th and still waiting for yesterday's result.
Only got a few pence for the 30th and 13th, for various reasons.
There's another saving hour this evening from 17:30, if you can opt in.
Posted by: @mjrOnly got a few pence for the 30th and 13th, for various reasons.
I have already opted in again to show my support, even though we never receive any recompense.
- 39 Online
By ASHP-BOBBA , 26 minutes ago
By ASHP-BOBBA , 32 minutes ago
This one is critically dependent on where you are in th...
By JamesPa , 1 hour ago
@jamespetts Lots of things to unpack here so I will co...
By JamesPa , 2 hours ago
By Tim441 , 5 hours ago
By Toodles , 5 hours ago
By Transparent , 6 hours ago
By HCas , 9 hours ago
By jamespetts , 10 hours ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
