Intelligent Octopus Go without an EV?
Posted by: @iancalderbank@toodles charge rate one of the best bits about powerwall, part of why I went for it over others. 5kw PER powerwall. I have 3 so can (and do) pull 15kw to grid charge them during off-peak. and that is enough to supply any sane house load peak (I've broken through 10kw briefly with everything on).
to show how you can make best use of them with the heat pump: Yesterday evening from 9pm to 1130pm was the first time I've had to buy any on-peak electricity at all since I went to a fully electric house in march last year. heat pump COP dropped due to it being brass-monkey weather , sub zero morning, and zero sun where we are.
So you are the culprit behind NG (or whatever they are called, or going to be called) having to carryout such excessive upgrades. 😋
- 2,171 Topics
- 47.8 K Posts
- 64 Online
- 5,744 Members
By cathodeRay , 2 minutes ago
If the 'cellular technology' is actually the GSM system...
By Transparent , 3 minutes ago
Is it reading high or low? Measurement of the outside...
By Old_Scientist , 5 minutes ago
@editor Wow Mars! I was just building up to phoning th...
By bontwoody , 9 minutes ago
@jamespa Ours is a Daikin EDLA03 8 kW and the Delta T =...
By Toodles , 42 minutes ago
Day one is done. The system’s been fully flushed and ...
By Mars , 15 hours ago
By cathodeRay , 17 hours ago
By Toodles , 17 hours ago
By Toodles , 18 hours ago
By Sheriff Fatman , 21 hours ago
By Paul G , 2 days ago
By pash44pump , 4 days ago
By JamesPa , 5 days ago
By Cleardene-ashp , 5 days ago
By JulianC , 5 days ago
