EV charger installation question – I don't want to bury the cable
Those markings are not the ones which tell us the conductor size, unfortunately.
Do you happen to have vernier calipers which could be used to measure the diameter of the black, grey or brown internal wires?
I'm assuming that the SWA cable has copper conductors of either 1.5mm² or 2.5mm²
Those sizes are difficult to discriminate based solely on external dimensions.
But perhaps this might help:
The exact figures differ between manufacturers.
Each SWA cable might use different plastics as the insulator.
The major problem with SWA are the losses, especially if it's in a duct or directly buried.
The IET assumes that direct burial is in dry ground, resulting in little heat escaping.
Running the cable in wet clay soils can allow you to pass higher currents, albeit you're then not complying with the IET specification.
- 23 Forums
- 2,098 Topics
- 46.2 K Posts
- 77 Online
- 3,385 Members
@editor It may be that. I do remember setting up a max ...
By bontwoody , 33 minutes ago
By Damon Blakemore , 6 hours ago
Just to update you all. I made up my own fill loop as...
By ohdearism , 7 hours ago
Hmm Before doing that I would want to be certain that...
By JamesPa , 11 hours ago
By Majordennisbloodnok , 11 hours ago
By Mars , 22 hours ago
By downfield , 1 day ago
By Sune , 1 day ago
By Aventus Eco , 3 days ago
By Tim441 , 3 days ago
By abam48 , 4 days ago
By Toodles , 5 days ago
