[Solved] Hot water issue, never seen this before: Grant Heat Pump and Cylinder
Hi all. A faulty mixer valve sounds like a likely cause to me too. Failing that there could potentially be some cross-flow going on; I notice on the photo of the combination pressure reducing valve, that the balanced cold outlet is plugged. Maybe there's a point in the system at which the higher-pressure cold supply is overpowering the reduced-pressure hot supply, travelling the wrong way down the hot draw off, and subsequently cooling the top of the cylinder down. A bit of a long shot, but this could be something to explore if a mixer valve issue is ruled out.
hi Tom, thank you and thanks to everyone else who replied.
it turned out to be a faulty shower that was causing the issue. This was closed off by a plumber and it fixed the issue straight away. Has now been replaced.
took 3 different plumbers to figure it out but we got there. Nothing to do with the pump or cylinder in the end.
- 2,131 Topics
- 11 Online
- 5,656 Members
By Tim441 , 4 hours ago
Anyone still weathering it out with Agile?
Being curious, I have continued to monitor the daily ra...
By Toodles , 10 hours ago
By JamesPa , 14 hours ago
By Tim441 , 1 day ago
By Toodles , 1 day ago
By Abernyte , 1 day ago
By Eliuccio , 3 days ago
By Scalextrix , 3 days ago
By Mars , 5 days ago
By Scalextrix , 5 days ago
By Toodles , 5 days ago
By Judith , 1 week ago
By Old_Scientist , 1 week ago
