Double heat pump for DHW?
How about this?
Posted by: @ianmk13I would imagine that that the availability of 4-phase ASHPs (compared to their single-phase siblings) may be a relevant consideration
It certainly would @ianmk13
There would appear to be an excess of phases to the tune of +1 🤗
Contrary to what we in UK might imagine, 3-phase heat pumps are plentiful.
The majority of domestic heat pumps being installed in mainland Europe are now three-phase.
Here, we can expect an installer to be specifying a 3-phase ASHP for 11kW and above.
But mainstream manufacturers like Samsung will happily supply a 3-phase 8kW unit if an installer chooses one (Model No. AE080RXYDGGEU)
As for those with storage batteries, there's no reason why an existing battery couldn't have the inverter(s) changed to provide 3-phase.
Although dedicated 3-phase inverters are available,
most 1ph inverters that can operate 'in parallel' are quite capable of being divided across the phases.
My existing Growatt SPF5000ES units offer that functionality,
as do the Sunsynk 5kW ECCO inverters which I will shortly be installing.
Inverters in parallel all use the same common battery, whether they are connected to single or three-phase mains input.
Posted by: @transparentPosted by: @ianmk13I would imagine that that the availability of 4-phase ASHPs (compared to their single-phase siblings) may be a relevant consideration
Sorry. Fat fingers 🤣
Posted by: @transparentAs for those with storage batteries, there's no reason why an existing battery couldn't have the inverter(s) changed to provide 3-phase
Not so with my GivEnergy All-In-One, unfortunately ☹️
Posted by: @ianmk13Not so with my GivEnergy All-In-One
That's a tricky issue, and one which I expect to see being raised many times this year (2025) as consumers begin to realise what GivEnergy's strategy means for them.
Have a look at what I posted as a synopsis of that strategy here on another topic.
It's a well respected company, and they've taken a hard-nosed decision to concentrate on the new iteration of their All-in-One system.
They will gain a lot of customers in the UK who 'just want a storage battery' and aren't going to spend much time researching the subject.
Most of them will be very satisfied with what they've had installed, and remain largely unaware of its constraints.
Posted by: @transparentIt's a well respected company, and they've taken a hard-nosed decision to concentrate on the new iteration of their All-in-One system.
Yes, that's another ball-ache coming so soon after my purchase of what will quickly become an obsolete system. In order to expand the storage capacity I will either have to add a further All-In-One, which includes another inverter (which will require DNO approval) or and a totally separate 'conventional' battery and inverter system (again, requiring DNO approval). That said, I will probably need additional inverter capacity for resiliance in any event once I install a heat pump - my present 6kW will be insufficient for 'whole home backup'.
- 2,750 Topics
- 64.7 K Posts
- 1,936 Online
- 7,158 Members
@papahuhu I prefer to look at it simplistically. We d...
RE: To re-pipe or not to re-pipe? Moving from oil boiler to air source heat pump.
Sooooo, what did we do in the end? We approached three ...
By Penval , 5 hours ago
RE: How Accurate Is My DIY Heat Loss Calculation?
D'oh - of course. I shouldn't post before my brain is f...
By Old_Scientist , 10 hours ago
RE: Questions about A2A for heating as well as cooling
@rob-of-york I would concur with the underfloor insulat...
By Toodles , 12 hours ago
RE: New Vaillant Arotherm controls link to existing thermostats ; wired vs wireless
Nothing attached! I have rads but UFH makes the case ...
By JamesPa , 12 hours ago
Passive cooling should always be the first call. Keep ...
By JamesPa , 13 hours ago
RE: Do I add Air Con or MVHR to existing A2W ASHP?
@rob-of-york Thank you, I’m thinking along these same l...
By Toodles , 1 day ago
@Mars Good questions! The downstairs unit did the maj...
By Rob of York , 1 day ago
RE: Volumisers in Heat Pump Systems: Does Placement Matter?
@dave, I think @jamespa has probably identified the mos...
My thought is simple. Bring it on and bring on plug in...
RE: Heat Geek mini store vs pump size
Yes I agree, that’s why Heat Geek have most likely sele...
By Tomtheheatingengineer , 3 days ago
@tomtheheatingengineer, thank you, and welcome to the f...
RE: HeatGeek vs Octopus surveys: puzzling disparity - any ideas why?
@majordennisbloodnok @tomtheheatingengineer For my ...
RE: Is the "divide by 2900" rule still valid?
Really flow rate is a pipework limitation not a water p...
