My ASHP is running ...
My ASHP is running out of hot water
6 Users
11 Reactions
20.8 K Views
@curlykatie
I hope that you will be providing your plumber and electrician with training certificates, once you have completed their training. 😎
(@curlykatie)
@derek-m 🤣🤣🤣 I most certainly will!! 🙈
(@curlykatie)
@derek-m another quick question! Now that the secondary pump is redundant does it need completely disconnecting or is it ok to leave with just the isolation valves off? Just thinking of the stagnant water sitting there!!
Posted by: @curlykatie
I would suggest that you open the valve and run the pump for maybe 10 minutes, preferably when you carry out the legionella cycle.
(@iancalderbank)
@curlykatie so that is a control group valve which is exactly as expected on a pressurised hot water cylinder
orient this picture against it. number 1 will go to the incoming mains from the street. 2 should be connected to the cold supply to the taps in your house. 3 to an expansion vessel (a dead-end, there purely to absorb pressure fluctuations). 4 to the supply into the bottom of your hot water cylinder. 5 to a discharge pipe that goes outside of the house somewhere, via a should-be-visible-to-the-user tundish - will only have water flowing out of it if there is a problem.
the interesting bit is where the cold supply to outlets is taken from . if its branched from before #1, then its at different pressure to that hot coming out of your cylinder and that is the issue with a fairly high degree of confidence. If its taken from #2, then its balanced which is correct, and thus the issue is something else.
isolation valves - unlikely to be in the mixer (But not impossible). look for access methods underneath bath panels, back of cupboards , behind plinths etc. its always really good to know where they are anyway, regardless of issues like this - if something leaks, you need to know where to turn off!
(@curlykatie)
@derek-m ok- I’ll see if I can get a switch added to the pump as it’s currently disconnected.
With regards to the legionella cycle- we have an emersion heater which we have to put on manually once a week to heat to 60 (and keen an eye on it as it goes way over this!). The plumber has suggested that the developers need to fit a timer to the emersion and that it is a ‘legal requirement’- just wanted to check this before I case them?!
(@curlykatie)
@iancalderbank thanks for your reply. I’ll check it out later when I’m home and update!!
If the water pump cable is long enough, you could just fit a standard mains 3 pin plug that you can use in a 240v socket.
Does your immersion heater contain a thermostat? If so, then adjust it to switch off at 65C. I do believe that in many of the systems the heat pump controller can be used to switch the immersion heater on and off, and can also limit the maximum temperature.
Have a look at your heat pump controller manual under the legionella cycle settings, to see if there is mention of controlling the immersion heater. It could be that you need to provide your electrician with further training, since you should not have to manual perform and monitor the legionella cycle.
(@curlykatie)
@iancalderbank I have orientated myself to the above and all seems to be in the right place!! I am
confused by your second paragraph and not quite sure what I’m looking for! Apologies- novice plumber here 🙈
(@curlykatie)
@derek-m there are 2 thermostats in the tank- the top 1 is linked to the Midea system, the bottom one (in the photo) I was told by the plumber doesn’t do anything?? Maybe this is the stat for the emersion… I can’t see anything on the immersion itself.
The Midea controller does seem to have an option for immersion but I was told by the installer they were not compatible!! So frustrating!
D6B433DD B5DB 471C 892A 74B65D8709E3
1CCAB685 1196 46A3 8AC4 4531C94E627A
A100F216 325C 4D04 A43F 5C21CC0B3111
BE175D12 C391 40FC A9BA F6A9060D6928
@derek-m thank so much for your reply. I really do appreciate it. I’ve attached some photos- let me know if you need anything else. I think one of them is the circulating pump,
katir
The white box on the side of the cylinder, shown in the first photo, who the the manufacturer and what is the model number? What is the scale on the dial?
(@curlykatie)
@derek-m see attached. FYI- the thermostats are now the other way round to the original photo!
2C021B7B 1C55 4697 86DD 41F95166B936
920C9EE5 64E2 4EF6 B3CC D3DE9BECE387
FD95DBE3 89E5 4C8B 9495 2DAAF7E6F485
Page 6 / 8
