The Grid Says Yes.. Until It Doesnt
There is a curious tension at the heart of Britain’s energy transition. On paper, the direction of travel is unequivocal: electrify heat, electrify transport, expand distributed generation and let households become active participants in a cleaner, more flexible grid. In practice, however, that ambition is increasingly encountering friction, not in the technology, nor even in consumer appetite, but in the infrastructure and governance that sit beneath it.
We have felt this tension directly. Our own system is, by most standards, unremarkable for a household leaning into electrification: a 6kW solar PV array, paired with a 6kW inverter and an 18kW air source heat pump. All of it approved under G99.
And yet, the moment we attempted to take the next logical step (adding 20kWh of battery storage) we found ourselves back at the starting line. The battery system comes with its own 3.6kW inverter. That seemingly modest addition triggers a fresh G99 application, which is fair enough. Our installer has submitted it, but his expectation is blunt: rejection is likely.
This is not an isolated anecdote. Across the country, installers are reporting a growing number of refusals from Distribution Network Operators (DNOs). The reasons vary in their technical framing (harmonics, fault level constraints, thermal limits, voltage rise) but the underlying message is consistent. The network, at least in its current configuration, is not always willing to accommodate the decentralised, electrified future it is being asked to host.
Harmonics, in particular, have become a recurrent justification. In simple terms, these are distortions in the electrical waveform caused by non-linear loads and inverters. Too much distortion, and sensitive equipment can malfunction; too little control, and system stability can be compromised. It is a legitimate concern. Modern grids are increasingly populated by inverter-based technologies (solar PV, batteries, EV chargers) and their cumulative impact is not trivial. But the invocation of harmonics as a reason for refusal is often opaque to the homeowner. It arrives as a technical verdict with little practical recourse.
Voltage rise is another frequent constraint. When households export electricity (particularly in rural or lightly loaded networks) the local voltage can exceed statutory limits. The more generation connected to a given feeder, the greater the risk. Thermal constraints follow a similar logic: cables and transformers have finite capacity, and sustained high export or import can push them beyond safe operating limits. Fault levels, meanwhile, relate to the maximum current that can flow during a short circuit. Add enough generation, and those limits can be breached, requiring costly reinforcement.
None of this is unreasonable in isolation. Grid stability is not a theoretical concern… it is the foundation upon which the entire system rests. The DNOs are, quite rightly, cautious. They are custodians of infrastructure that was never designed for millions of small generators pushing power back upstream. Their challenge is structural as much as operational.
The difficulty arises when that caution begins to collide with national policy. The UK is actively encouraging households to install heat pumps, to adopt electric vehicles, to generate their own electricity and to store it. Each of these moves increases reliance on electricity, while also offering flexibility that could, in theory, support the grid. Batteries, for instance, are not merely passive assets. Properly integrated, they can absorb excess generation, reduce peak demand and provide ancillary services. They are part of the solution.
And yet, at the point of connection, they are often treated as part of the problem.
Consider a more typical British home. A semi-detached property installs a 4kW solar array under the simplified G98 process… no prior approval required, provided export is limited. Encouraged by rising energy prices, the homeowner then adds a 5kWh battery with a hybrid inverter. That upgrade may still fall within permissible limits, depending on configuration. But the moment they consider expanding, perhaps adding a second battery, or upgrading the inverter to enable higher discharge rates, they can find themselves pushed into G99 territory. The process becomes slower, more complex and increasingly uncertain.
Or take a household installing a heat pump. Electrification of heat significantly increases peak demand, particularly on cold winter evenings. Add an EV charger into the mix, and the load profile becomes even more pronounced. In theory, a battery could mitigate that demand, charging during off-peak periods and discharging when needed. In practice, the very addition of that battery may be constrained by the network’s perceived limitations.
There is a structural paradox here. The technologies that could alleviate grid stress are, in some cases, being constrained by the grid itself.
G100, which allows for export limitation devices to cap the amount of electricity fed back into the network, was meant to offer a workaround. By ensuring that export never exceeds a predefined threshold, it provides DNOs with a degree of certainty. Yet even G100 applications are, increasingly, subject to scrutiny and, in some cases, rejection. The reasons again return to system integrity: concerns about compliance, enforcement and the cumulative effect of many such systems operating simultaneously.
The result is a growing disconnect between policy ambition and operational reality. Households are being told to electrify, but not always being given a clear or reliable pathway to do so. Installers are navigating an increasingly complex landscape of applications, assessments, and conditional approvals. And the DNOs, for their part, are managing a system under strain, with limited visibility of what is coming next.
It is worth asking whether the current framework is fit for purpose. G99 was designed in a different era, when distributed generation was a niche rather than a norm. Its processes, while robust, are not always aligned with the speed and scale of the transition now underway. The question is not whether standards should be relaxed (grid stability cannot be compromised) but whether they can be modernised.
There are models elsewhere that hint at a different approach. More dynamic connection agreements, for instance, could allow assets to operate within flexible limits, responding in real time to network conditions. Greater standardisation of inverter behaviour (particularly around harmonics and voltage support) could reduce uncertainty. Enhanced data sharing between households, aggregators and network operators could improve forecasting and planning.
But these are not trivial reforms. They require coordination, investment and a willingness to rethink long-standing assumptions about how the grid operates.
In the meantime, households are left navigating a system that can feel inconsistent. One application sails through, another, seemingly identical, is refused. One DNO takes a pragmatic view, another applies a stricter interpretation. For the average homeowner, the experience is not one of a coherent national strategy, but of a postcode lottery.
There is also a broader economic question. Electrification is not just a technical transition, it is a financial one. Households are being asked to invest significant sums in new technologies (heat pumps, batteries, EVs) often with the promise of long-term savings and environmental benefit. When those investments are delayed or derailed by connection issues, confidence is eroded. The risk is not merely individual frustration, but a slowing of adoption at precisely the moment it needs to accelerate.
None of this is to suggest that the DNOs are acting unreasonably. On the contrary, their caution reflects the seriousness of their mandate. But the system as a whole appears misaligned. Policy is pulling in one direction… infrastructure and regulation are, at times, resisting.
The deeper question is whether Britain is attempting to run a 21st-century energy transition on a 20th-century grid architecture. If so, the friction we are seeing is not an anomaly, but an inevitability.
For now, our own battery application sits in that uncertain space between ambition and approval. It may be accepted, perhaps with conditions. It may be refused. Either outcome will be instructive. But the broader issue will remain. Electrification, in principle, is straightforward. In practice, it is mediated by a network that must evolve as quickly as the technologies it is being asked to support.
Until that alignment is achieved, the path to a fully electrified Britain will remain, in subtle but significant ways, constrained not by what households are willing to do, but by what the grid is prepared to allow.
Mice, Vermin and Your Heat Pump
Octopus Energy launches Cosy Octopus to make heat pumps more accessible and affordable
1 Comment
As I was reading this article Mars, I was thinking that your ‘Dynamic’ is the key to all this now; I thought in terms of ‘Smart’ exporting where some control signals from the smart meter (perhaps @Transparent may be able to answer this) are used to indicate to the consumer / exporter’s equipment whether that golden sunshine’s energy would be welcomed by the local grid at that particular moment or not. Such a flexibility might allow for the DNO’s to avail themselves of as much power as they could safely handle on the local network at that time. Watching my own system I see just how dynamic that supply / demand system changes second by second with a heat pump sucking it up and the inverter pushing out all that it has available or is permitted to by my G99 application.
Any system with one or more variables needs ‘rules’ or restrictions to protect the infrastructure further up / down the line; with variable loads and surpluses (never mind phase imbalance etc!), there is a lot going on. To produce a system that is flexible rather than just dictatorial obviously needs management – smart management maybe? Perhaps this could be achieved using controls that listen to smart meter signals?
Local energy storage is possibly one of the better solutions but can Mr. & Mrs. Average afford this investment? Regards, Toodles.
