Domestic wind turbines
Came across two small turbines. Will contact the respective manufacturers for more details and what additional kit is required. Not cheap though:
https://www.truenorthsailing.co.uk/wind/1710-6475-silent-wind-400-pro-wind-generator.html#
https://futurenergy.co.uk/feshop/airforce-1-wind-turbines/
Found out CAT in Wales does a domestic wind turbine day training. I'll let you know if it's interesting in a couple of weeks.
https://cat.org.uk/events/build-a-small-wind-turbine/
https://cat.org.uk/events/renewables-for-households-wind-turbines/
They do a variety of courses on different subjects.
Interesting place to visit and chat to people generally
@jeff, sounds amazing. It says all materials provided. Does that mean you’ll walk out of there with a turbine? That would be tremendous value. 😀
Posted by: @editor@jeff, sounds amazing. It says all materials provided. Does that mean you’ll walk out of there with a turbine? That would be tremendous value. 😀
It is a two day residential group course where you get to make and build a turbine on site as a group including food and accommodation.
Everyone on the course doesn't walk out with a turbine unless i missed something.
Still good value to learn about these things.
Am sure you would pickup really practical real world info on domestic solutions in general.
@jeff, I was joking about walking out with a turbine. 😀
It does genuinely sound like a very interesting course. Hands on training like that is amazing.
Hadn't even seen that one! I found the one day course:-
Figured it'll be a good start to see what the training is like there.
Just seen a group in Bristol has privately financed a £4m turbine.
- 37 Online
@jamespa That flow rate sounds rather high James! Regar...
By Toodles , 1 hour ago
@jamespa thanks, I appreciate the offer. For n...
By DREI , 11 hours ago
@transparent what I don't understand about these "rogue...
By Scalextrix , 14 hours ago
I have 3 women in the house, 2 little ones, so my heati...
By DREI , 16 hours ago
@damon thanks. I will do as you suggest. Hopefully I wi...
By bontwoody , 17 hours ago
By pash44pump , 2 days ago
By Cleardene-ashp , 3 days ago
By JulianC , 3 days ago
By ASHP-BOBBA , 4 days ago
By Lucia , 4 days ago
By ASHP-BOBBA , 5 days ago
By Tim441 , 5 days ago
By Transparent , 5 days ago
