Using Night Briquettes and Air Source Heat Pumps to Lower Energy Bills
The battle against high energy bills has become a familiar struggle in many homes. As winter tightens its icy grip, the question looms: How can we stay warm without breaking the bank? One of the most effective methods I have discovered involves combining the use of our air source heat pump (ASHPs) with night briquettes in our wood-burning stoves. We have two wood-burning stoves that radiate heat throughout our main living areas and bedrooms. In my experience, this combination not only offers a sustainable heating solution but also proves to be economically advantageous.
ASHPs are a popular choice for environmentally conscious homeowners due to their efficiency in converting air into heat. However, their performance can take a hit during extremely cold weather, which is where briquettes come into play. Night briquettes have become our go-to choice for supplementing our home’s heating system. These briquettes are designed to burn slowly, releasing heat steadily throughout the night, ensuring that the house remains warm even when temperatures outside drop significantly.
Why Choose Night Briquettes?
While there are various options available on the market, Night briquettes stand out for several reasons. They are made from natural bark, making them a more sustainable choice as they are essentially made from a waste product. Their slow-burning nature means that we don't need to reload the stove frequently, which is a convenience on chilly winter nights. In fact, when we put two briquettes in the wood burner before going to bed and we often wake up to some embers still glowing.
Long-Term Savings
The investment in a wood burner (if you don’t have one already) and the cost of the briquettes themselves might seem like an additional expense. However, the long-term savings are evident in reduced electricity bills. Over the course of a harsh winter, these savings can be significant.
Furthermore, wood burners and briquettes prove to be lifesavers during winter and storm-related blackouts. In times when power outages can render heating systems useless, having a wood burner fuelled by reliable briquettes ensures that we can keep our home warm and comfortable. This aspect of self-reliance is particularly crucial in severe winter conditions, where maintaining warmth is not just about comfort, but also about safety. The efficiency and dependability of these briquettes in such scenarios truly underscore their value as an essential part of our home heating strategy.
Furthermore, the lifespan of the ASHP is extended as it's not overworked during cold spells. This reduction in wear and tear translates into lower maintenance costs and delays the need for a replacement, which is another financial benefit.
Tips for Night Briquette Usage
To maximise the benefits, it's crucial to use night briquettes efficiently. Here are some tips:
- Proper Storage: Keep the briquettes dry to ensure they burn efficiently. Moisture can reduce their effectiveness.
- Controlled Burning: Adjust the air supply to your stove to control the burn rate. A slower burn rate ensures the briquettes last longer, maintaining a steady temperature throughout the night.
- Regular Maintenance: Keep your stove clean and well-maintained. A clean stove improves the burning efficiency of the briquettes.
- Integration with ASHPs: Use briquettes primarily during the coldest parts of the day or night, relying on the ASHP during milder temperatures. This balanced approach optimises energy usage and cost.
The combination of night briquettes and ASHPs is a practical solution for cost-effective home heating. As someone who has personally experienced the benefits, I can vouch for the effectiveness of this method. Lekto’s briquettes, in particular, have added a layer of efficiency and sustainability to our home heating system. By embracing this approach, homeowners can enjoy a warm, comfortable home environment while keeping an eye on both the environment and their wallets.
- 2,378 Topics
- 53.9 K Posts
- 157 Online
- 6,060 Members
RE: Grant ASHP 17.5 kw. weather curve
Firstly welcome to the forums. I hope you ar...
By JamesPa , 8 hours ago
@toodles We had a reroof concurrently with the PV in...
By Papahuhu , 8 hours ago
RE: Cascade 2x Grant Areona 10kw ASHP - Ongoing setup issues
(Almost) all heat pumps do defrost by taking heat from ...
By JamesPa , 9 hours ago
The Great British Heat Pump Owner Persona Survey: Let's Build Our Archetype!
Happy New Year everyone! As we head into 2026, ...
By Mars , 9 hours ago
Seems to be the only logical explanation. Our ASHP was ...
By benson , 11 hours ago
@jamespa thanks, yes it seemed mad to me. An exert f...
By Papahuhu , 11 hours ago
RE: Optimum new build house design for Heat Pump
From first principles I would say: Definitel...
By JamesPa , 12 hours ago
As good a place as any to drop this video:/p>
By Mars , 16 hours ago
@transparent D'Oh - I did look before I posted but I mi...
By dr_dongle , 17 hours ago
Compatibility with Samsung AE080RXYDEH
I am new to all this. We have a SamsungAE080RXYDEH that...
By John999 , 17 hours ago
@batpred Maybe you should buy your additional batter...
By Bash , 19 hours ago
RE: Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
@nursethescreens Yes, comfort and happiness of the fami...
By Toodles , 20 hours ago
Thanks folks. I had tried googling an ethernet lab adap...
By z8lccda , 1 day ago
RE: Changing from 4-port buffer to volumizer
@toodles I'm not concerned that the behaviour is not no...
By Andy1618 , 1 day ago
I agree, and I think there are two things in play here....
RE: Water Hammer After Heat Pump Install
That's really helpful. Yor last sentence confirms it'...
RE: Help needed with Grant Aerona 3 issues
First time posting so bear with me. Some bits that have...
By Adamp , 3 days ago
RE: Mitsu PUHZ-SW120YHA + EHSC-VM20Uk - Performance
All understood. Obviously its a bit house de...
