Should I dump the FiT for SEG?
So we currently are getting FiT payments - 5.9p/kw for Export and 4.1p/kw for Generation. The question is, should I dump this move to the SEG or even Outgoing Octopus. Octopus SEG is 3x the rate at 15p/kw and outgoing has topped over 50p/kw this last summer. I know the FiT is guaranteed for 25 years, but at 15p thats cash back in 8 years and at 50p/kw its only 1 or 2 years.
I am thinking move to SEG over the winter and then onto Outgoing for the summer months. Open to peoples thouhgts.
Also as an update I had our mains gas capped and the meter removed this week. No more standing charges for un-needed gas.
Congratulations on moving off gas!
Do you stand to benefit in a non-financial way from the move away from FiT (e.g. easier to change the panels or inverter)? Making financial judgements are more tricky to assess, given current volatility. Or are you eventually planning to move to something like Octopus Go (in which case I'm sure you know the Octopus Outgoing option is unavailable)?
@chickenbig I'm on Go. But you can just shift tariff over the summer when I don't actually buy any power
- 2,658 Topics
- 62.2 K Posts
- 393 Online
- 7,060 Members
Directory
@jamespa I am all for pre engineering… Would I be ...
By Batpred , 13 minutes ago
RE: Who Actually Owns a Heat Pump in Britain? We Asked. Here Is What We Found.
I am getting my house ready for a heat pump. In the las...
By Fred Gray , 33 minutes ago
@majordennisbloodnok I came across this by accident and...
By DavidAlgarve , 34 minutes ago
That tells me your highest priority is cost per kWh, ra...
By Transparent , 2 hours ago
@trebor12345 Good to hear of another satisfied Cinergi ...
By Toodles , 2 hours ago
On the two huge (10m² each) south facing windows I inst...
By bobflux , 4 hours ago
RE: GivEnergy inverter tripping due to over-voltage?
@transparent I don't think Axle have any involvement...
By Tim441 , 4 hours ago
RE: Failed Heat Pump Install: IWA Claim Rejected
Many of the estimates we received mention IWA and RECC....
RE: Rural burning – I've had enough
Same here in Finland. It's strictly forbidden ...
By upnorthandpersonal , 1 day ago
Something worth flagging... we've just published a news...
The Homeowners' Q&A podcast is back... I've changed...
RE: Anyone concerned about GivEnergy?
I have already signed up with Axle so yes, that takes c...
By KevH , 1 day ago
@batpred Would it pass the airbnb feedback test no. I...
By EtchedPixels , 2 days ago
A quick update... we've just launched the beta version ...
