Removing Fireplace Gas Fitting
i have had the gas supply removed from the house and have removed the old gas fire from the living room but am left with the gas supply fitting protruding from the floor (wooden boarding) and would like to remove it flush with the floor. I cannot see any fixing screws in the two holes in the baseplate of the fitting so before I take a hacksaw to it, I thought I would enquire here in case a reader could advise please; how is this fitting held in place? I am attaching a photo of the fitting in case this helps. Regards, Toodles
Posted by: @toodlesi have had the gas supply removed from the house and have removed the old gas fire from the living room but am left with the gas supply fitting protruding from the floor (wooden boarding) and would like to remove it flush with the floor. I cannot see any fixing screws in the two holes in the baseplate of the fitting so before I take a hacksaw to it, I thought I would enquire here in case a reader could advise please; how is this fitting held in place? I am attaching a photo of the fitting in case this helps. Regards, Toodles
Hi, if you tease back the carpet there should be a flange with screws. Remove them and lift the fitting and there is a compression fitting holding the pipe. Anyway that is if it is like mine! cheers
Daikin 6Kw ASHP.
A further thought if you are not removing the pipe is to fit a stop end or you will get a smell of gas.
Daikin 6Kw ASHP.
- 2,772 Topics
- 65.3 K Posts
- 1,376 Online
- 7,174 Members
By Old_Scientist , 35 minutes ago
@ian-s I wouldn't be too concerned about the design ...
By Rob of York , 1 day ago
@renewables345 I would say if it a new build it’s no mo...
By Aventus Eco , 1 day ago
Posted by: @batpred There´s another aspect that coul...
By Jimcub , 2 days ago
By Prunus , 2 days ago
Thank you @majordennisbloodnok – that means a lot, part...
By Papahuhu , 5 days ago
