Understanding iDM Terra
Hello, Can anyone help me understand how to optimize the configuration of my iDM Terra system? The manual (presumably translated from Austrian ...) isn't a great help for me - but might help you more (!) and can be found at https://manualzz.com/download/7445057
I'm particularly keen to know how best to configure the Priority charging (see 4.1.2 on manual page 16) - but also curious to know what EVU Blocking is (5.1.4, p.25), and frustrated by the fact that although it is apparently possible to download system data from myidm.at I have been unable to do so.
With thanks in anticipation!
I think EVU blocking is typically a feature that enables you to block the power supply from the energy provider in situations where there is an excess production of renewable energy in your system. When your solar panels or other renewable energy sources generate more energy than your household or building requires, the excess energy is often fed back into the grid. However, in some cases, it may be more beneficial to keep the energy within your own system, rather than exporting it back to the grid.
So it’s a way to prevent the energy from being exported back to the grid and instead using it to power other appliances in your home or building. This feature can help you maximise the use of your renewable energy and reduce your dependence on the grid.
EVU blocking should only be used in specific situations and should be configured correctly to prevent any issues with your energy supply.
I'm not sure if that helps you.
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
- 2,783 Topics
- 65.6 K Posts
- 1,246 Online
- 7,187 Members
I've got a podcast recording scheduled this week where ...
By Mars , 2 hours ago
I’m a little late posting this, but it’s genuinely one ...
Ah, that makes sense when a combi is in place. The boil...
By Batpred , 4 hours ago
@bobflux Thanks, that gives me something to check the i...
By Paul1098 , 5 hours ago
Without doing some research I can't immediately answer ...
By JamesPa , 6 hours ago
For Powerwall calibration, avoid forcing repeated deep ...
By EnergyStorageTech , 13 hours ago
By bobflux , 1 day ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 1 day ago
By bobflux , 2 days ago
By Andris , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By downfield , 4 days ago
