Replacing Worcester...
Replacing Worcester oil boiler with an ASHP
27 Users
182 Reactions
37.9 K Views
@julianc, that's brilliant. Big day ahead. Hope it all goes according to plan.
JulianC
(@julianc)
Thanks Mars. I was joking with Ecobubl, they leave all the doors open, so the home is cold. And you are just grateful for any heat when they switch the ASHP on 😊
JulianC
(@julianc)
C9519C01 945C 4BCC 9DBC 8CA318A8633E
Mixergy slimline 180L hot water tank installed. But not fully connected. There is an external heat exchange (not shown) for the ASHP. Can also integrate the solar PV. Still requires internet connection. And pipe insulation.
JulianC
(@julianc)
External Daikin Altherma 3H HT installed. But still to be commissioned
635CF756 B18C 4C20 8D6A 1B94BB5D137E
Looks good eh?  This is an 18kW unit. Single fan
4
Very nice!  Keep the updates coming.
@julianc, that is very snazzy. Love the design. Can we get a size pic too when you get a chance?
JulianC
(@julianc)
Daikin Altherma 3H HT is 990mm high by 1270mm wide by 460mm deep or 0.578m3. Below the planning regs 0.6m3 limit. It is also one of the quietest ASHPs on the market with a sound pressure of 38 dBA at 3m. And uses R32 refrigerant - which is better for the environment. I have water only in the circuit between the external unit, internal unit and 27L buffer tank.
More photos to follow as job progresses
JulianC
(@julianc)
And the fan behind the black grill
8B9C8FAC DD87 40A7 B689 2D96289F8C12
Quite cool actually
JulianC
(@julianc)
Detail of the internals
7262786A B159 4EC4 AE67 5A8B8B985D80
We are all wired up. But the Daikin is not recognising the Mixergy tank at the moment. More work to do. And tidying up
JulianC
(@julianc)
Ok, so 95% of work completed
4710E898 BA9B 4592 92EF CB950B1F5B2B
Outdoor unit all working
44970876 0CFC 4DDA 9157 C496E068E7FB
Indoor unit in the garage (above)
FE9AC5DB FDB3 420E 8E93 F8EE5DF26F33
Buffer tank and pump for around the radiators
And finally the Mixergy tank in the airing cupboard  Note the insulated heat exchanger at the bottom and the control module at the top  Whilst the tank is heating, at the moment it is not from solar PV or the ASHP  Mixergy sent the wrong component for the Daikin  So my engineer will be back Wednesday to fix  Can still schedule and control Mixergy thru the app
So now we just need to learn how to use it  Interestingly, the recommendation is to treat it like a boiler and schedule it to come on, rather than on all the time
Time will tell  Happy to answer any questions
Looks like a nice job @julianc.  We schedule our heating to come on and off using the zone thermostats. This works OK and the house seems to warm up quickly enough.
@julianc, it all looks terrific. Hopefully we'll have a few coolish evenings to see how your system copes, and which will help set a baseline for performance. How exciting.
Page 2 / 16
